General Automotive Discussion
Electric fan help
Old Apr 17, 2008 | 01:08 PM
Fair 96's Avatar
Fair 96
Electric fan help
I am thinking about changing my 16 in fan on the motor to electric fan on the radiator. (my current fan has no shroud and is about 2 in from the radiator) I am wondering if 2 10 in electric fans (they are rated at 1570 CFM each) pulling air through the radiator would cool the engine enough or is the regular fan better? Any help appreciated.
Old Apr 17, 2008 | 05:49 PM
rebocardo's Avatar
rebocardo
Year, model, engine, ac, transmission type, etc. ?
Old Apr 17, 2008 | 06:11 PM
Fair 96's Avatar
Fair 96
73 small block 4 speed co a/c
Old Apr 17, 2008 | 09:05 PM
vman's Avatar
vman
No aftermarket fan pulls as much air as the 3.8 taurus fan.It will pull over 4000 cfm.You can get them cheap and they are two speed.
Old Apr 18, 2008 | 08:34 AM
gezn2's Avatar
gezn2
I've been researching this a little lately, no aftermarket fan is going to be as durable or move as much air as some of the stock units you can pick up at the junkyard
The Taurus units are great, but the absolute gold-standard right now seems to be the '93 to '98 Mark VIII unit. If you're not using a fancy controller your electrical system has to be ready for 100 amp spikes on startup and 35 amp draw when it runs but it moves one *heck* of a lot of air
Old Apr 18, 2008 | 10:39 AM
fmc400's Avatar
fmc400
MSEE
I think 10" would be a little small, considering that the radiator core on that truck is about 19 inches tall, so effectively you're leaving half of the radiator without air flow, even though you are getting near-complete horizontal coverage. It may heat up a little at idle, but since you don't have a trans. cooler you may be OK. I'm in the proces of swapping one into my '79; I'm using a 16" fan. The stock fan on my truck was about 17". The Taurus fans are famous but I don't have much room to work with in my setup so I had to go with a farily thin (and unfortunately lower CFM) fan.
Old Apr 18, 2008 | 01:34 PM
galaxie641's Avatar
galaxie641
I've never had good luck with the 3.8L fans and had no trouble with derale 16" fans. The only thing you want to pay attention to is getting as much coverage of the radiator as possible. I also like dual fans in case one fails you still have some cooling capability. If you can't run 2 fans then obviously go as big as possible with one or buy a smaller one with a shroud built in to suck air through the whole radiator.
Old Apr 18, 2008 | 01:46 PM
xtrford's Avatar
xtrford
I have one taurus fan cooling my 5.4l and it does an excellent job....temps hold steady and that is on the low speed. I adapted the fan to my stock shroud which helps pull air across the whole rad....very important.
Old Apr 18, 2008 | 05:03 PM
Ford_Six's Avatar
Ford_Six
Get a factory electric fan or a good aftermarket one. Don't cheap out. I got my Galaxie cheap because someone put an electric fan in, then proceeded to overheat it until the head gasket blew and the valves sunk in the heads. This was on an engine with less than 5k on it, and the electric fan system was fairly new.
I would go with a Be Cool or Flex-A-Lite system, but that puts you in the $500-$800 range. The Explorer, Expedition, Crown Vic, Taurus, later Thunderbird V8, and most Lincoln cars have a fan that can be adapted to the older truck radiators.
I would use a non-adjustable controller like Summit SUM-890015 - Summit Electric Fan Thermostat Kits - summitracing.com
Old Apr 18, 2008 | 05:22 PM
rebocardo's Avatar
rebocardo
I agree with the others for the 302 V-8 you should really use the Taurus fan with a relay, temp. switch, and perm. on/ perm. off switch of course.
Old Apr 18, 2008 | 08:45 PM
Fair 96's Avatar
Fair 96
I appreciate all the replies . Thank you all very much.
