F350 Guys
Old Apr 17, 2008 | 11:28 AM
FordF350Baby's Avatar
FordF350Baby
F350 Guys
I got a 1995 F350 4x4, what have you guys with 3.55 gearing do that wanted to fit 35 inch tires? I want to get 4.10 gearing and a few add a leafs to be able to fit some 35's on this monster. I dont know how much its gunna cost to get new gears installed and add leaves
Old Apr 17, 2008 | 11:33 AM
str8racing's Avatar
str8racing
If your'e going to change gearing go to something like 4.56 , 4.10 is not enough. You can get gears from someplace like bronco graveyard and then have someone install. Should be able to do it for around 400.00, makes a big difference.
Old Apr 17, 2008 | 11:38 AM
FordF350Baby
wont 4.56 impair my highway driving?
Old Apr 18, 2008 | 06:36 AM
78bigunns's Avatar
78bigunns
Find a tire size/gear ratio calcualtor.
It should give engine rpm's at a given speed based on your 35's and 4.56's.
I would think the 4.56's would keep you within specs for motor rpm's with the 35's.
Old Apr 18, 2008 | 08:37 AM
78bigunns's Avatar
78bigunns
try this calculator, use the one on the left side, E4OD for tranny, BW 1356 for transfer case, 4.56 for gear ratio, and 35" tires, at 25oo rpm you'd be doing 80mph.
You can play with the numbers too:
Gear Ratio Calculator
Old Apr 18, 2008 | 10:41 AM
DJdemon6696's Avatar
DJdemon6696
i think 4.10 will be fine.. he does allot of highway driving.. so 4.10 will be best.. i have 4.10 and im upgrading to 35"s soon and i wont change the gears
at 80 you will be hitting 2445 RPM so its no big difference between the 4.56's
Old Apr 18, 2008 | 11:08 AM
krol's Avatar
krol
4:10's should be fine. I had 3:55's and was running 36" tires and could still squeel them off the line. Now I'm running 4:56 gears but that's because I want to run a bigger tire. I wish I had 4:10's instead for highway and you can always use 4Lo when you need it offroad. What engine do you have? That will also determine how doggy/not it is while driving.
Old Apr 18, 2008 | 12:39 PM
FordF350Baby
shes a big girl 7.5L
Old Apr 18, 2008 | 12:51 PM
krol's Avatar
krol
Awesome, you should be fine. I also have the 7.5L so it's comparable.
Old Apr 18, 2008 | 01:00 PM
DJdemon6696
btw... i forgot you can fit 35's just fine under a F350.. another guy on here has 36's on an f350 with no lift
Old Apr 18, 2008 | 02:17 PM
str8racing's Avatar
str8racing
sorry i always think of towing too, so you need the 4.56 for towing with 35's.
Old Apr 18, 2008 | 04:03 PM
FordF350Baby
o really? hmm i wld try and stay away frum those and just go with a 305 tire
Old Apr 18, 2008 | 04:15 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
alright there is something fishy about that calculator...
I checked it with
e4od
bw1356
4.10 gears
35" tires
it said in 4th gear at 5k rpm the vehicle would be going 179 mph?????? WTF?
Old Apr 18, 2008 | 06:08 PM
tjc transport's Avatar
tjc transport
i ain't rite
try the 35's with what you have.
if you were closer to N.J., i would gladly swap the 4.10 rears i have in my 88 for your 3.55's.
i have 36's on the 88, and am always looking for another gear.
