Really busted '96 Exploder 5.0 AWD
Old Apr 16, 2008 | 11:12 PM
wiski's Avatar
wiski
I've got a '96 5.0 AWD Explorer thats really given me a headache.
It started out with a rough idle, then one morning I come out and the truck won't start. Infact the fuel pump won't even prime. I thouight I'd diagnosed it down to a bad pump, but I've pulled the tank and swapped the pump (everything is still on the ground at this point) and I'm still not hearing the pump prime, so I've restarte ALL of my diagnosgtic tests.
I've swapped the fuel pump relay with the one from my g/f's 97 6 banger.
Her car starts and runs; mine won't
I moved relays in my car; the WOT A/C relay and the fuel pump relay
Still no luck with priming.
I checked fuse #3 (20 amp).
It looks good visually and even my fluke meter shows its conductive
I did notice ~ 10.4 volts on the circuit when I removed the fuse (the voltage reading is consistant if I have the car in the "on" position or "off.
Fuel safety shutoff inertia switch
Looks good - I even pushed on it to see if I could reset it, but its already "reset".
The "you're not getting fuel light on the dash is NOT on
Checked computer codes
Nothing shows up.
I'm desperate for answers and I'll try to check back every half hour just incase anyone who's on at this hour has any ideas.
Thanks in advance to anyone with ideas.
--Jonathan
Old Apr 17, 2008 | 12:09 AM
wiski's Avatar
wiski
Nevermind it was my fault. I neglected to connect the very large yellow connector under the chassis (under the driver's seat). I plugged that back in and the pump primed! Talk about a minor heart attack .........
Thanks for reading anyways!
--Jonathan
Old Apr 17, 2008 | 09:17 AM
CobraXP's Avatar
CobraXP
Glad you got it figured out. I can honestly say I know the feeling. That is a been there - done that moment for me also...
fordmania
Nov 25, 2012 02:08 PM
capriceragtop
Jun 23, 2012 10:59 AM
94posexplorer
Jul 10, 2011 10:34 AM
kapdma
Mar 16, 2009 08:54 PM
TzOldbat
Mar 1, 2005 01:29 PM
