'92 ranger starter problems
Old Apr 16, 2008 | 10:00 PM
willworkforbeer's Avatar
willworkforbeer
About a week ago my ranger started doing intermittant starter inop, so I changed the fender-well solenoid, no help. So I put in a new starter, now it is consistant starter inop. Is there a splice in the wire from the fender-well solenoid to the starter? Or is there something else I should be looking at, I Have jumped the fender soleniod to no avail. Any help would be greatly appreciated!!!
Old Apr 16, 2008 | 10:46 PM
ford2go's Avatar
ford2go
Hopefully you can find a voltmeter. Sounds like there's a bad cable or ground connection.
I'd check to see how much the voltage dropped between the battery plus and the fender solenoid when you try to start it. I'd also check the negative side to the engine itself. The starter picks up its ground through the engine.
It gets less fun after that because you have to look for drops on the starter itself.
Also, look at the physical condition of the grounds -- including the mesh one that goes to the engine. Also, what was the condition of the wire that you hooked to the starter, If it was already cruddy ( technical term), wiggling it around could have made it worse.
ford2go
Old Apr 16, 2008 | 10:51 PM
Rangerman Stan's Avatar
Rangerman Stan
You could start by checking all the cables and smaller wires that go from the battery to solenoid to starter for corrosion and good clean tight connections. Check that you get power to the small solenoid wire when you turn the key to start position. Also check the condition of the ground wire from the engine to the body. All of these need to be in good condition to have a complete circuit. Then if it's still not right, check the start switch down on the steering column under the dash. The contacts on it may be worn out.
Old Apr 17, 2008 | 02:19 AM
87 XLT's Avatar
87 XLT
As mentioned it sounds like a bad cable.
If you have a set of jumper cables try this simple little test.
Jump from the positive on the battery to the starter relay & see if it starts.
No Joy? try from the negative of the battery to the engine block.
When I had this same problem on my 87 & i jumped from negative post to block & it fired right up I knew the negative cable was shot.
Old Apr 18, 2008 | 04:32 AM
willworkforbeer
It turned out to be the cable from solenoid to starter. 87XLT that was a very good "trick of the trade" that I've never heard of before, THANKS.
Old Apr 18, 2008 | 10:55 AM
87 XLT's Avatar
87 XLT
Yeah, thats a simple little trick to find a bad cable.
Thanks for the update, glad you got it figured out.
Ryan Weaver
Jan 4, 2015 04:30 PM
F2504x4
Modular V10 (6.8l)
Jun 26, 2014 05:36 PM
montanamilitia
May 29, 2013 12:33 AM
Old Blue Eye
Jul 31, 2005 09:32 PM
bigsquirt
May 28, 2004 07:51 PM
