range sensor?
Old Apr 16, 2008 | 07:24 PM
qusmarine's Avatar
qusmarine
range sensor?
dones the 03 6.0 have a range sensor? trying to troubleshoot a delayed and confused 1-2 shift
Old Apr 16, 2008 | 08:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes it does. It's inside the trans. I don't think it is your problem, though.
Old Apr 17, 2008 | 01:20 AM
doubledee715's Avatar
doubledee715
fwiw, I had a delay from p-r-d and Mark K. recommended changing the external filter first. (ft145) qusmarine, are you running any type of "power adder"?
Old Apr 17, 2008 | 12:25 PM
qusmarine's Avatar
qusmarine
no i am not, with what mark says, maybe i will just chaange out the solenoids in the pan... ? maybe? we hooke dup a tester in middrive and the computer reads that the shaft speed sensors are working correctly, that was my next guess?
Old Apr 17, 2008 | 04:51 PM
doubledee715
As told by mark when I was having tranny issues, there will only be a solenoid code if the delay is at least 5 seconds. I think that's why he recommended changing the filter first to help clean any crud out of the solenoids. Also, if the tow/haul hasn't blinked on and off then there isn't a code. When that blinks, it means there is a tranny code.
Old Apr 18, 2008 | 05:54 AM
qusmarine's Avatar
qusmarine
it does take up to 4-5 seconds and it will switch into failsafe mode(blink on off) and i THINK the code was P0126, but i will ahve to hook it all up again after i get it out of the sshop
TomHewett
Sep 22, 2014 01:45 PM
wfodickinson
Jul 14, 2007 11:10 AM
mtgrzlyman
Sep 3, 2005 10:21 PM
RobertJohn
Jan 8, 2005 10:00 AM
