Sponsored by: Auxito
No Heat - Help
Old Apr 16, 2008 | 01:29 PM
sheehast's Avatar
sheehast
No Heat - Help
I have a 1999 F150, 4.6, 4x4, supercab. Last night whil driving I went to turn on my heat and cool air came out (No the A/C was not on). I adjusted things, moved from def to panel to floor, no changes. I changed from heat to cool to heat, nothing either. I also removed the temp dial to make sure it was actually adjusting and it was. I do not have and coolant leak as a Heater Core would produce, atleast like in my old Chevy's where it would leak coolant onto the floor of the passenger side. There doesn't seem to be anything out of the ordinary, just no heat. Anyone have an idea on what to check???
Old Apr 16, 2008 | 01:45 PM
KingRanchMan02's Avatar
KingRanchMan02
Sounds like you may have a broken blend door. Good luck!
Old Apr 16, 2008 | 01:56 PM
sheehast's Avatar
sheehast
That, according to a couple web sites is 5-6 hours of work. Is there any way to verify sure this is a junk part before I replace all of this???
Old Apr 17, 2008 | 07:17 AM
sheehast's Avatar
sheehast
A new twist, last night on my way home the truck heat worked as always. This morning however, cold air blew out when on heat???? What's going on?
Old Apr 17, 2008 | 08:18 AM
phil6608's Avatar
phil6608
Try changing the thermastat. Cheep place to start.
It may be sticking open.
Old Apr 17, 2008 | 11:13 AM
KingRanchMan02
It keeps sounding more and more like a broken blend door. These threads have some good information. The last link is details on how to replace the heater core and it takes about as much work to get to the blend door as it does to get to the heater core. Good luck!
https://www.ford-trucks.com/forums/697229-1999-f150-blend-door.html
https://www.ford-trucks.com/forums/620047-anyone-with-blend-door-motor-directions.html
http://my.voyager.net/~sscully/F-15097HtrCoreRepairF150_Exp_002.doc
Old Apr 17, 2008 | 12:16 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
Sounds like the blend door motor to me. keep them in stock kinda a common problem.
2L3Z-19E616-BA
Ed
