5" exhaust
Old Apr 16, 2008 | 12:11 PM
Night Bird's Avatar
Night Bird
5" exhaust
I can not find anybody that makes a 5" kit for the 7.3. Is there a clearence issue on the X, that is not on the F250.
Thanks
Old Apr 19, 2008 | 03:51 PM
kawajockie's Avatar
kawajockie
Check with Mark at MKO Power - Quality Diesel Products At Competitive Prices
My guess is it won't fit between the rear shock and the gas tank!
Old Apr 19, 2008 | 03:57 PM
bigdog55's Avatar
bigdog55
I asked several 4x4 places around here and looked on-line and was told that you only use a 5" for rigs over 400 hp or so..The hp may be different,but the idea was that,for some reason,the 7.3L only should have a 4",unless it's REALLY jacked up in hp.
Old Apr 19, 2008 | 04:55 PM
scottman70's Avatar
scottman70
A 5" system won't fit between the shock and fuel tank, it's very tight with a 4" inch system.
Old Apr 19, 2008 | 09:30 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
But you could always make it dump out before the back tire and it would work
Old Apr 20, 2008 | 11:29 AM
Night Bird's Avatar
Night Bird
Thanks guys I appreciate it. I have some kind of exhaust on it now will try to get a picture, of it. It is pretty big but not sure, what size. It is not a full system though just muffler and tail pipe, hooked in to stock and out the back. But it is a good bit bigger than stock. What is stock size.
Thanks
Old Apr 20, 2008 | 06:48 PM
kawajockie's Avatar
kawajockie
Stock is 3.5.
There are lots of folks that like the 5" on the 7.3, but as mentioned earlier, you would have to re route it as it wont fit by the tank.
Either way, if your going to buy a system, call MKO power. They have great deals!
Seems like the most populare for the
EX are MBRP and Silverline.
Old Apr 20, 2008 | 11:55 PM
Night Bird's Avatar
Night Bird
Might just cut if before the axle. Gonna put it on a lift and look at some differnent options next week.
Thanks
robert_l_ross
Jun 20, 2024 10:16 AM
xTraveler
May 26, 2024 10:21 PM
stock54f100
Apr 30, 2015 05:13 AM
johnsteffy
Sep 6, 2013 11:49 AM
TSBRONCO
1978 - 1996 Big Bronco
Mar 29, 2005 04:19 PM
