99 starting problem -
Old Apr 16, 2008 | 10:54 AM
tsjries's Avatar
tsjries
I have noticed a random starting problem on my 99 Explorer Sport 4.0. SOHC <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
When I turn the key the starter begins to crank and all the sudden stops for a split second then resumes cranking again. It reminds me of when the timing is off and you try to start the engine and two cylinders are firing at the same time. <o></o>
<o></o>
Typically, I have had starters fail completely but this weakened condition has me a bit baffled. Has anyone else experienced this type of starter failure? <o></o>
<o></o>
The vehicle has 150,000 miles on the original starter so I am planning on replacing. The battery is about 2 winters old. <o></o>
Old Apr 20, 2008 | 11:36 AM
marragtop's Avatar
marragtop
I would check to make sure all your wiriing connections to the solenoid and starter are good and not corroded.
KRDiesel
New Mexico Chapter
Apr 23, 2008 01:18 PM
UGLYFORD79
Apr 19, 2008 12:40 AM
ngates
Dec 6, 2005 06:45 PM
mckishen1
Feb 4, 2005 05:54 PM
parker53029
Nov 8, 2004 05:46 PM
