6.0L Intercooler swap
Old Apr 15, 2008 | 11:31 PM
FivePointo's Avatar
FivePointo
I have an opportunity to get a 6.0L Intercooler for my 2001. I know it's been discussed before. What sort of benefit might I see. I believe the 6.0 is supposed to have 25% greater cooling area. I tow a 12K 5th wheel and my egt's run around 850 on a flat run I let out when they get too far over 1000(That's in Florida's heat/humidity with the a/c on max). Thanks
Old Apr 15, 2008 | 11:35 PM
jtharvey's Avatar
jtharvey
As long as you keep pre-turbo EGT's under a sustained 1250, you shouldn't have any problems as it is now. With that being said, the 6.0 IC will only benefit you while towing. It will drop EGT's 100-150 degrees. Other than that, I saw no benefit in it when I tried it. Spool is the same, boost is the same, and empty EGT's did not change. Only when loaded or towing did it seem to help any.
Old Apr 16, 2008 | 06:32 AM
bdrummonds's Avatar
bdrummonds
Yep, Jeremys right on with this one. Been there, doin it now, it will lower your EGTS while towing.
Old Apr 16, 2008 | 11:22 AM
jwhitetail's Avatar
jwhitetail
If your going to change intercooler go with the Speraco 6.0 racing cooler, you will see difference empty and pulling.
Old Apr 16, 2008 | 11:31 AM
just another truck's Avatar
just another truck
if he just disconnected the wastegate, wouldnt he see the EGT's go down as well??
