i have a 70 f250 camper special with a 390. i want to do a compression test on the engine. can anyone tell me the specs on this. i know its old and will prob be a little low but i want to know how far i shoud go in the engine. also im looking to replace the cam, im looking for a cam that will be good for daily driving and pulling a 6000lb camper. any help will be apreciated. thanks
What you are looking for in an older engine is for the cylinder pressures to be relatively close. Within 20-25%.
I would not put a cam in an older engine. Add-ons like intake, carb and headers would be as far as I'd go, as whatever is nearly worn out will show itself in short order as the power goes up. And if you are in it deep enough to change the cam, go all the way.
Does your truck still have the stock exhaust manifolds? The easiest upgrade is headers and dual exhaust. Stuffing more in does little good if it can't get out, and most 390s have pretty bad exhaust manifolds.
I might have a similar problem with my F250 1970 as "big 390".
390 w C6 tranny, engine runs really good, but there is no power left when driving.
I had it at a chop several months, they changed rocker arms, rebuilt Holley carburetor etc etc, everything thats in the top... pretty much. Still about 100psi...
Anyone having a clue what to do next?
Have done a cylinder test and they are all at the same level.
Exhaust manifolds nice and new aluminum, also changed headers to aftermarket parts, new custombuilt Magnaflow 2,5" exhaustsystem....
A lot of the parts are almost new, like distributor and fuel filter etc etc.
Me and the mechanics have runned out of ideas...
My first thought were the piston rings... but as a girl -Im never seriously taken
(it used to have lots of power, and its been slowly going away..)
If you only have 100 psi cylinder pressure, even with oil squirted in the cylinders, your motor is wore out....
Honey while that may be, it has many more miles left. I wouldn't start worring until you have some 30s mixed in. It is a long ways from being dead. IMHO
what im trying to find out is what should the psi for a compression test should i consider acceptable. i have put on headers with dual exhaust. i have removed the points and replaced with crane cams system and a new coil. new plugs, wires and fuel pump.it runs good and all but it doesnt have the power for pulling my camper especially up any slight grade hills i get slowed down to 45 mph with my foot to the floor in drive. the kick down linkage isnt on it becouse it wont fit prob becouse its old and someone has changed something or left something off i guess. im wanting to replace intake and carb but a cam is cheaper.
Last year, I had issues and had two cylinders that were dead. I had head work done and because of sloppy work at the machine shop the new guides were shot and the valves were not holding compression.
I suspect from what you have described you have issues other than worn rings. The truck FE 352, 360, 390 pull like caterpillars. Until recently the FE was one of the best pulling engines that Ford ever built.
The headers don't do much for pulling, they do more for high rpms. A factory 2 barrel setup should tow anything that you want.
Go to Autozone or another place and borrow/rent a compression gauge and do the test.
From what I read you may have two or more sparkplug wires crossed, a bad vacuum leak but I doubt your compression is shot.
You gotta do the test, worring about it aint gonna tell you anything.
You should fix it so it will shift to 2nd when it needs to. Now, the compression test...think 150 psi as the cylinder pressure. If it's 130, that's ok too. What you want is for them to be fairly close. 150 150 100 30 150 30 145 100 would be not so hot. If they all fell between 120-150 that would be ok. Do the test, post the numbers, you'll feel better.
