My truck is a 79 4x4 with a 460. with an auto. tranny, originally a 400 with a manual tranny.
My fuel gauge hasn't worked sence I bought the truck so I checked everything suggested and everything has been checking out. I got under the truck again and started tracing wires thinking maybe I missed something. I found a cut wire going to the front tank so I fixed that. that wasn't it them I reached all around the front tank and found anouther wire that wasn't even attached to any thing. I traced it all the way to engine compartment and it isn't attached to anything there either. Then as I looked longer in the engine area I notice wire connecters that weren't going to any thing. I'm really confused. Everything else is great just no gas gauge. Where can I get a wiring diagram so maybe I can at least figure out where to start with this. Thanks
Check your gauge by grounding the sender wire at the tank (momentarilly) doing this should peg it to "full". Also check the selector switch if you have 2 tanks. In my experience the sender is at fault most of the time. It wouldn't hurt to check/clean connections at the back of the instrument cluster.
My truck had the problem of gas gauge not working and it was the brass float inside the gas tank had a hole in it, it was full of gas and wouldn't float anymore. Just check that after you ground the wire running to the gauge to make sure it pegs the gauge and the shows the gauge and wiring is good.
This is the wire that was on top of my front tank not hooked to anything.
the wire wrapped in my finger below is the one that is laying on my gas tank not attached to any thing I'm guessing the other connectors in the photo are for the options my truck doesnt have.
The green wire is the wire that was cut to the front gas tank. I repaired and heat shrinked. What is that wire because the black wire below it is the one hooked to ground?
After looking at the diagram the common point to both tanks is at 507 on the left side of diagram. So I need to find that point right and check power there?
