74 f250
Old Apr 15, 2008 | 06:50 PM
roostnu074's Avatar
roostnu074
74 f250
trying to find out if i can drop a 6.9 diesel into my 74 f250. it already has a 390 but its out of power and needs alot of work. and gas milage is not that great either. also will my c-6 tranny bolt to the 6.9??
Old Apr 15, 2008 | 09:18 PM
fire7882's Avatar
fire7882
c6 should bolt up fine. I'm not sure about the mounts but you should have room and the wireing should also be fairly easy. You may also need new fuel tanks for a diesel.
Old Apr 16, 2008 | 12:10 AM
mattsautobody442's Avatar
mattsautobody442
you'll have to find a vrv for the c6 to operate correctly
Old Apr 16, 2008 | 12:57 AM
RCrawler's Avatar
RCrawler
The FE C6 will not work behind the diesel. You'll need to find a diesel C6 to match the bellhousing pattern.
Jason
Old Apr 16, 2008 | 01:23 AM
roostnu074's Avatar
roostnu074
what is the vrv??? this is something new to me. iv always been into the 7.3 but i never looked into it enough to know alot.
Old Apr 16, 2008 | 01:32 AM
RCrawler's Avatar
RCrawler
Vacuum Regulating Valve specific to the diesel C6. I believe that it controls shifts based on engine load, like a vacuum modulator.
Jason
Old Apr 16, 2008 | 02:09 AM
roostnu074's Avatar
roostnu074
ok the other guy mentioned something bout getting that for the c6 that i have now, will that work or no??
Old Apr 16, 2008 | 07:33 AM
fellro86's Avatar
fellro86
If you are referring to the FE C6, you would have to get an adapter plate made up to make it work, it won't even come close to bolting up, a 460 comes close, but not quite. A headache you will have to see if will work out is the steering linkage clearing the oil pan, as it runs behind the crossmember, while the diesel trucks run it ahead of the cross.
Old Apr 16, 2008 | 10:14 AM
mattsautobody442
yeah, you could use a cable linkage setup from a newer truck. the VRV uses vacuum from the pump, and the throttle at the IP to create a signal the modulator can use to shift correctly
Old Apr 16, 2008 | 10:29 AM
RCrawler's Avatar
RCrawler
I think his truck is a 4wd, so that shouldn't be an issue.
Jason
Old Apr 17, 2008 | 12:14 AM
mattsautobody442
i was thinking of the kickdown linkage
bronkntrukholik
18
Oct 21, 2009 10:02 PM
roostnu074
16
Apr 25, 2008 06:37 AM
roostnu074
Apr 22, 2008 03:30 PM
Fordbronco69
Dec 6, 2004 04:20 PM
ssjophus
15
Jan 12, 2003 11:28 PM
