Interior Lights
Old Apr 15, 2008 | 05:51 PM
FordCrazy1970's Avatar
FordCrazy1970
Question Interior Lights
my inteior ligths dont work but when i squeeze the relay(with the relay cover off )the lights work. Could it be the power saver relay?The door ajar light on the insturment panel works,and goes off when the doors close.
Thanks ,
Mike
Old Apr 15, 2008 | 10:44 PM
Franklin2's Avatar
Franklin2
What year and model truck? Sounds like a newer one.
Old Apr 17, 2008 | 05:30 PM
FordCrazy1970
1998 f 150 5.4 2 wheeldrive
Old Apr 17, 2008 | 06:16 PM
zx250's Avatar
zx250
Of the next Riffraff East
Sounds like you need a new relay. Replace it and see what happens.
Old Apr 17, 2008 | 08:01 PM
Franklin2's Avatar
Franklin2
I figure he is forcing the relay closed by squeezing it. I will have to look in my diagrams to see which one it is, but it might be a blown fuse.
Old Apr 18, 2008 | 05:09 PM
FordCrazy1970
I can squeeze the relay for the dome light and the map lights and they work but thats the only way they work.
Old Apr 18, 2008 | 06:34 PM
Franklin2's Avatar
Franklin2
Have you checked the fuses? I forgot to look it up.
Old Apr 18, 2008 | 09:17 PM
FordCrazy1970
Yes I checked the fuses all checked good.
Old Apr 19, 2008 | 08:38 PM
Franklin2's Avatar
Franklin2
The GEM module is what activates the interior light relay. Look under the dash at the fuse box and the GEM module, and see if you have any signs of water leakage. Sometimes the windshields leak on these models, and the water runs down and damages the GEM module.
Old Apr 20, 2008 | 10:52 AM
FordCrazy1970
Ok I'll Check GEM thanks .
Old Apr 29, 2008 | 07:14 PM
FordCrazy1970
Thanks for the help ya'll.Fixed the problem it was the 2 small relays in the interior fuse block.
Thanks ,
Mike
