Adding off road/ work lights
Old Apr 29, 2008 | 11:41 PM
ghostguy6's Avatar
ghostguy6
Hi, I am trying to install some off road lights onto a toggle switch in the cab of my 96 explorer. I tried to tap into the electircal connections on the cigarette lighter plug at the bottom of the dash but I am always blowing a 30amp fuse under the hood. I have checked the wires and there are no nicks in the insulation and all the solder joints are shrink wrapped so I dont think there is a short in the circuit. Is there another place I can tap into a 12 volt power supply? Unfortunately I dont have the specs on the off road lights.
Old Apr 30, 2008 | 12:13 AM
Franklin2's Avatar
Franklin2
Take them apart or whatever you have to do, but you need this info to make sure you have enough capacity in your wiring and where you get the power from.
rigs906
Mar 19, 2011 07:36 PM
1bad67sbf
Mar 28, 2010 11:56 AM
El_Rodney
May 10, 2009 07:52 PM
1-bigmac
2004 - 2008 F150
Jan 30, 2008 08:57 AM
DuckRyder
16
Aug 15, 2003 04:20 PM
