Wheel tilted
Old Apr 15, 2008 | 10:07 AM
ttttmaxx's Avatar
ttttmaxx
Wheel tilted
Gents I had a 4" lift installed over the weekend and when I got it back I notice the steering wheel is now cocked a little bit just enough to annoy you. The shop said they did an alignment but I had issues with this shop and decided to not return there. Whats the best way to put the steering wheel back straight without going to get another alignment? Its a 1997 powerstroke 4 wheel drive. Thanks Maxx
Old Apr 15, 2008 | 10:49 AM
Neal 97 250's Avatar
Neal 97 250
1- remove the steering wheel and straighten it and replace.
2- remove steering arm from gear box and move 1 spline till it is straight
3- adjust left tie rod end in or out 1/4 turn and adjust right tie rod end in or out (opposite what you did to the left) until it is straight. Be sure to adjust each side identical to what you did to the other side.
While 1 and 2 are plausable options I would do #3. It will most likely give you the results you want and be more accurate.
There is always option #4, just tilt your head slightly till the wheel magically looks straight. LOL.
Old Apr 15, 2008 | 10:53 AM
ttttmaxx's Avatar
ttttmaxx
Neal are you referring to removing the pitman arm? Thanks
Old Apr 15, 2008 | 11:20 AM
BlueMule's Avatar
BlueMule
The splines on the pitman arm and shaft are indexed and you can't do it that way.
Make the needed corections at the steering linkage.
Old Apr 15, 2008 | 12:11 PM
Neal 97 250
I was referring to that in #2, yes.
The tie rod ends would be the easiest and most accurate though.
Old Apr 15, 2008 | 12:25 PM
Action4478's Avatar
Action4478
On Mine ,the steering wheel can be staightened with the collar on the drag link,,, don't mess with the tie rod ends if you don't have to....
Old Apr 15, 2008 | 12:26 PM
Cuda_jim's Avatar
Cuda_jim
ROTFLMAO
Thanks, I needed that!
Old Apr 15, 2008 | 12:35 PM
Neal 97 250
I don't have that option;
On mine (4X4) coming off the pitman arm is an arm that goes to the passenger tie rod end. and coming off that arm near the drag link another arm that goes to the drivers side tie rod end.
The only place to adjust my linkage is at the tie rod ends.
Don't worry though if you pay attention and be sure to adjust both sides the same you will be fine. Not very hard to do.
Old Apr 15, 2008 | 12:40 PM
tjbeggs's Avatar
tjbeggs
Yes the answer to this question depends on if we are working a 250 or 350? 250 you will need to use Neal's method of turn each tie rod turn buckle equal amounts in opposite directions (shorten one lengthen the other) (best to have a shop do it if you not comfortable with it) or if its a 350 you can turn the turn buckle at the pitman arm without affecting toe in/out.
Old Apr 15, 2008 | 01:06 PM
Neal 97 250
And the master has spoken LOL... Thanx Tim for clearing that up. I wasn't aware of the ability to adjust the 350's in a different way. I guess you learn something new everyday.
Old Apr 15, 2008 | 01:31 PM
tjbeggs's Avatar
tjbeggs
Yeah the 350 has different linkage than the 250 due to the axle design.
Old Apr 15, 2008 | 02:11 PM
ttttmaxx's Avatar
ttttmaxx
Thanks for the help gents. When I get home I will crawl under and see if I can do the buckle at the pitman arm as Mine is the 350. Thanks again! Maxx
Old Apr 15, 2008 | 02:58 PM
IceboxFX's Avatar
IceboxFX
lets see some pics of the truck too
Old Apr 15, 2008 | 03:08 PM
Robbgt's Avatar
Robbgt
Tim, how's tis done? so there's a turn-buckle under that that will adjust steering wheel? Will it be obvious when I look under truck? Thanks!!
-Robb
Old Apr 15, 2008 | 03:17 PM
tjbeggs's Avatar
tjbeggs
Yes on a 350 with dana 60 straight axle the turn buckle closest (less than a foot away) to the pitman arm and steering gear is to straighten the steering wheel. There is one on the tie rod that adjust "total" toe in/out then you use the other one on the drag link to center the steering wheel
