Bronco II Ford Bronco II
Major Mess...2.9 Heads!!!
Old Apr 15, 2008 | 07:53 AM
fenix1's Avatar
fenix1
Went to swap heads out on my 2.9 Bronco. Got to the exhaust manifolds and some "NUT" managed to round the boltheads off bout half of em' I guess after changing the gaskets. So, gonna have to pull heads with manifolds still attached and then grind the boltheads off. Question: How do you manage to get the bolts out of the exhaust manifolds from the crossover flanges??? Looks to me like Ford jammed the engine in there with the crossover already attached. Ya can't get to the bolts from underneath and I can't see how in the world you could get to em' from above!!! Any suggestions would really be appreciated cause I'm bout to "pull my hair out" messing with this thing!!!
Old Apr 15, 2008 | 12:36 PM
tbolt 460's Avatar
tbolt 460
you can get the bolts from underneath
Old Apr 16, 2008 | 12:40 AM
HBYHRS87's Avatar
HBYHRS87
I concur,
I just removed the exhaust system from my 88 B2. What a pain. You gotta get creative with the extension and swivels, oh and a cheeter bar doesn't hurt either. I also had to use my Craftsman stripped bolt remover tools to get the Y pipe to cat joint apart. Love this tool now! Good luck on yours.
Old Apr 16, 2008 | 07:09 AM
8588ranger's Avatar
8588ranger
I 'd remove the front fenders with the inner plastic attached. (It's a pain to get the rusted phillips screw off). Then you will have more room to work on bigger problems.
Old Apr 16, 2008 | 05:34 PM
fenix1's Avatar
fenix1
DUH!!! Why didn't I think of that!!!
I guess by the time I got to the Exhaust Manifolds everything had gone so smoothly that when I saw or felt those rounded off bolt heads and then seen what a major B___H it was gonna be to get the Manifolds off I freaked. After reading this evening what you guys posted I went out and took a look at my little Bronco and after climbing up on my milk crate and carefully and CALMLY taking a look at it I think you are right. I think I CAN get to those thing from underneath and like one of you said, I'll just have to get creative. And like one of you said, If I CAN'T for some reason get them out I can sure pull the fenders and get to em". Guys, I really apprecciate all your' help!!! Been on this website for a couple of years now and I've never been disappointed!
88' Bronco II-2.9ltr.-5 speed-Auto Lock Hubs
10.5x31x15's Mud Kings-Everything Stock
Gonna do the Body Work on some rust spots soon and Paint it "Daytona Yellow". Should look good with all that Flat Black Trim...Maybe a little Pin Striping too.
Again...Thanks Guys!!!
