help id this sensor
Old Apr 15, 2008 | 01:49 AM
spazinweasel's Avatar
spazinweasel
help id this sensor
some have called it a filter blokage sensor but others say its on the fpr this is on the bottom rear of the filter housing
thanks for any and all help oh its a 95 ps
Old Apr 15, 2008 | 05:42 AM
Cuda_jim's Avatar
Cuda_jim
Here's the official name:
Fuel Filter Restricted sensor;
on filter housing 94/95;
on regulator block 96/97
(Ford) E8TZ-9S283-A
(International) 1809435c1
Same sensor...just located in different places. Some call it a Fuel filter Vacuum sensor. You don't need it if you are diligent about changing the filter. I've seen some pretty nasty looking filters and have not had the light on the dash come on.
Old Apr 15, 2008 | 07:02 AM
MADVAN's Avatar
MADVAN
X2 Cuda!!!
Seems many of these have started to leak since the ULSD.
Bill
Old Apr 15, 2008 | 09:10 AM
BlueMule's Avatar
BlueMule
X3
All it is is just a vacuum operated switch that lights the "fuel filter" light on the dash. If you can remember to change the filter without an idiot light to remind you that it's time just replace it with a brass 1/8 NPT pipe plug. Just be carefull not to overtighten it or you can crack to fuel canister (or FPR on the 96-97's)
Old Apr 15, 2008 | 09:52 AM
spazinweasel
thanks everybody im not ssure if ill plug it or find one but this one is toast
Old Apr 15, 2008 | 10:49 AM
spazinweasel
so the stealership wants 64$ for the sensor i deleted it
Old Apr 15, 2008 | 12:05 PM
Cuda_jim's Avatar
Cuda_jim
Try the IH dealer $14 last time I checked....if you really want to get one.
Old Apr 15, 2008 | 04:44 PM
spazinweasel
thanks i may try that later
4tl8ford
1692
Mar 5, 2026 05:58 PM
CelticDevilDog
2004 - 2008 F150
19
Apr 11, 2021 07:23 AM
4tl8ford
Aug 22, 2012 07:58 PM
93f1505.0L
Jan 18, 2010 08:23 AM
93f1505.0L
17
Jan 5, 2009 07:20 AM
