How to: replace rear leaf sprint brackets??
Old Apr 14, 2008 | 09:54 PM
78ford351m's Avatar
78ford351m
My rear leaf spring brackets are shot and rusted off the frame. Are these hard to replace? My bed is off the truck.
Old Apr 14, 2008 | 11:18 PM
mark a.'s Avatar
mark a.
The only thing that can give you trouble is if the through bolt is siezed.
Old Apr 14, 2008 | 11:27 PM
ErrorS's Avatar
ErrorS
are you talking about the spring hangers? if so, you have to drill out the rivets and it isn't fun.
the bolts themselves for the leaf springs aren't easy to get off either, had to use a 6' cheater bar on a breaker bar to break mine loose.
Old Apr 14, 2008 | 11:39 PM
75F350's Avatar
75F350
Since the hangers are ruined already, they will be a snap to remove. You can easilly grind all of the heads off of the rivets, and punch them through the frame. This will leave a clean hole. New hangers can then be bolted up. Be cautios with 1/2" hardware, as this can leave the holes in the hanger a little thin.
The rest is really pretty easy and straight foward.
I even grind the head off of the bolt for the spring itself. Probably should consider replacing it anyway, so cutting the head off is not a bad decision.
Old Apr 15, 2008 | 12:24 AM
ErrorS's Avatar
ErrorS
On both sides of mine I wasn't able to get the rivets out without drilling them. Hand punch, air hammer, it didn't matter. If you have trouble just drill through the center of the rivet on the inside of the frame, it releases pressure and lets you punch though.
Old Apr 15, 2008 | 05:35 AM
77460ford's Avatar
77460ford
Once the rivet is out use a punch on the hole to round the edge a little, this prevents any cracking later once you bolt the new hanger on.
Old Apr 15, 2008 | 07:53 AM
78ford351m's Avatar
78ford351m
I'll give that a shot. I'll get you guys some pictures too. Thanks!
Old May 4, 2008 | 01:38 PM
Bonkrr's Avatar
Bonkrr
You southern guys and your riveted spring hangers. LOL I'd be willing to bet that any truck of this vintage in Nova Scotia that isn't on it's third set of spring hangers never saw winter. Seriously though, as mentioned, if you are changing the shackles too, they are the biggest pain to remover. After days of soaking with Moovit (great penetrant) punching, grinding, drilling....the finally came out, but what a major pain. I spotted a couple of good spring hangers and a really good bumper at the local junkyard the other day I am planning to go liberate on my day off this week.
Old May 4, 2008 | 06:34 PM
oaskills's Avatar
oaskills
I had to cut all of my bolts off to change the rear leafs and shackle bushings. If you need the replacement bolts or bushings Broncograveyard.com was very easy to work they had all that that I could not find anywhere else and It was a lot cheaper too.
