Where to start?
Old Apr 14, 2008 | 07:52 PM
tafy5's Avatar
tafy5
Where to start?
Engine light came on, had the codes read P0171 and P0174. Engine runs rough at idle. It has even cut off a few times. Where should I start?
Old Apr 14, 2008 | 08:20 PM
KINGDELL91's Avatar
KINGDELL91
wow WTF why is everyone having the same problem at the same time...
Old Apr 14, 2008 | 09:37 PM
buzzard's Avatar
buzzard
tafy5, start with IAC valve or pcv tubing. Try a search of the codes you listed and you'll find hundreds of relevant discussions.
Old Apr 17, 2008 | 06:10 AM
Gevans17's Avatar
Gevans17
P0171 and P0174
Clean your MAF
Old Apr 17, 2008 | 08:15 AM
sbclemens's Avatar
sbclemens
I had both of these codes at the same time. Turned out to be a crack in the elbow of the pvc tube where it meets up with the intake manifold.
Old Apr 17, 2008 | 06:19 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
A Haynes manual will cross reference all codes.
Tim
Old Apr 17, 2008 | 08:17 PM
FTE Herman's Avatar
FTE Herman
Also check OBD-II - On-Board Diagnostic System
Old Apr 18, 2008 | 01:39 PM
roboteacher's Avatar
roboteacher
that last plug
I was having one of the codes ( I don't remember which) and I took it to my mechanic who found the last plug (all the way back on the driver side) had never been changed (140K+). He changed the plug which I understand is a real **&&^#^$ and everything is fine.
Old Apr 19, 2008 | 07:38 PM
Mark62's Avatar
Mark62
Originally Posted by roboteacher
is a real **&&^#^$
Thats an understatement...
Old Apr 19, 2008 | 10:16 PM
sbclemens's Avatar
sbclemens
I think the rear on the passenger side is the worse. You sure it was the drivers side?
Old Apr 20, 2008 | 02:35 PM
tafy5's Avatar
tafy5
Question
I cleaned the MAF. If there was a leak in a tube would there be suction at the PCV valve?
Old Apr 20, 2008 | 03:12 PM
eallanboggs's Avatar
eallanboggs
The "PCV valve" doesn't create "suction" as you put it. It vents pressure to a vacuum source(suction) which is your intake manifold. A fault here would cause you to run lean on both banks which is what I guess your 2 DTCs say your O2s are telling you without looking them up. Handle your MAF with kid gloves. They are very delicate. You need to look for something that's common between Bank 1 and Bank 2.
