Sponsored by: Auxito
blower switch problem?? help please
Old Apr 14, 2008 | 07:09 PM
mikieday's Avatar
mikieday
got in my truck today (2001/F150 4x4 off road)
turned on the ven and turned the switch to the first position and nothing...turned it to the 2nd and 3rd position and they were working fine
what should i do to track this down? is it a major deal
thanks
Mike
Old Apr 15, 2008 | 06:08 AM
Ron W.'s Avatar
Ron W.
Are you referring to the blower motor speeds or the air flow direction?
Old Apr 15, 2008 | 06:13 AM
mikieday's Avatar
mikieday
the blower motor
Old Apr 15, 2008 | 06:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mikieday
the blower motor
You turned the **** to the first position = nothing.
You turned the **** to the second and third position, motor/switch, it all works.
If the blower motor doesn't work, neither will the switch - - in any position.
The switch controls the speeds, not the motor.
You prolly have a bad switch.
Old Apr 15, 2008 | 06:20 AM
Ron W.'s Avatar
Ron W.
First guess, blower motor resistor.
Old Apr 15, 2008 | 06:47 AM
mikieday's Avatar
mikieday
it is alot of work to do (switching the switch)? i am no wrencher..lol
and the resistor, what is it and how can i check it or replace that
thanks guys
Mike
Old Apr 15, 2008 | 07:26 AM
NumberDummy
4L3Z19A706AA .. Blower Motor Resistor (replaces F4ZZ19A706A)
MSRP: $18.78 / ftepartsguy.com price: $13.52.
According to the parts catalog illustration, it's located on the outside of the A/C-heater plenum chamber.
On the 1979 and earlier trucks (which I'm far more familiar with), when the resistor goes bad, nothing works.
(The original blower switch Ford part number (F65Z19986A) has been updated, and I couldn't find the new replacing part number-that's why I didn't post the info)
Old Apr 15, 2008 | 07:29 AM
mikieday's Avatar
mikieday
is there a place on the net i could look up a pic of were this is...and is it testable with a meter?
same for the switch too...is there somewhere to look that might show the disassembly
Old Apr 15, 2008 | 08:40 PM
jimm66's Avatar
jimm66
It should be located behind the glove box. Mounts on the heater plenum.
Old Apr 16, 2008 | 06:09 AM
mikieday's Avatar
mikieday
thank you.
do you or anyone know how to get to the switch ?
Old Apr 16, 2008 | 06:21 AM
NumberDummy
thank you. do you or anyone know how to get to the switch ?
Sure, from FoMoCo.
Contact FTE sponsor ftepartsguy.com (Parr Ford-Bremerton WA) for assistance.
The blower switch is still available, but the original part number (F65Z-19986-A) has been updated by FoMoCo (like the duly noted "blower resistor" part number was I posted above).
I have no ref for the new switch part number, so contact ftepartsguy.com
ftepartsguy.com gives a discount to FTE members from the actual Ford suggested retail price (MSRP). See post #7 for an example.
Ford updates 1,000's of part numbers a year, keeping up with all the part number changes is a PITA!
Mikieday, any Ford dealer will have parts catalog illustrations of what you're looking for.
I also told you in post #7 where the resistor was located.
Old Apr 16, 2008 | 06:57 AM
mikieday's Avatar
mikieday
thanks for the info..
got the glove box door off but that is about as far as i got.
looking deeper into it...2 settings are not working on the switch..i am leaning more to the switch on this problem, i would think if the resistor was bad that maybe (and i dont know) nothing would work...but maybe the switch just faild in two spots..
i dread tearing the dash apart i have never even had the radio out of this thing in 200k miles
Old Apr 16, 2008 | 09:44 AM
jimm66's Avatar
jimm66
Normally when the resistor board fails you just have high blower. This is a common problem in most vehicles, all makes. Like the other post said, contact FTEpartsguy. I have gotten parts from him, very fair and fast shipping.
Old Apr 16, 2008 | 10:00 AM
mikieday's Avatar
mikieday
i did contact him, thank you.
is there a way to test the resistor ? to make sure it is bad, they are not real expensive but i dont want to get something that i dont need..but it is alot less money then a switch...
Old Apr 16, 2008 | 10:49 AM
KingRanchMan02's Avatar
KingRanchMan02
I would be more suspicious of the BMR than the switch. There are four terminals on the BMR and three resistors on the board. You will need an ohmmeter to check it out. Each of the resistors can be check individually as follows. Pin 1 to pin 2 is 1.38 ohms. Pin 1 to pin 4 is 0.62 ohms. Pin 3 to pin 4 is 0.33 ohms. Good luck!
