Sponsored by: Auxito
front axle vibration
Old Apr 14, 2008 | 06:13 PM
jnicho6's Avatar
jnicho6
I have a vibration noise in the front sounds the same as when i'm in 4wd. the 4wd is disengaging at the transfer case and also at the soleniod on the front axle. Well at least its moving. Is it possible something might have broke inside or could it be something else?
Old Apr 14, 2008 | 07:19 PM
sclariat's Avatar
sclariat
Start by checking the diff fluid.
Old Apr 17, 2008 | 05:41 PM
jnicho6's Avatar
jnicho6
no it wasnt the fluid. My mechanic says it sounds like a wheel bearing. but It doesnt get any louder or quieter when cornering. How long does a wheel bearing last before it falls off. I've a long trip ahead and I wont be able to get it to a garage until next week.
Old Apr 17, 2008 | 07:26 PM
Ultramagdan's Avatar
Ultramagdan
That is a gamble I wouldn't take. How long is the trip?
Old Apr 17, 2008 | 08:47 PM
sclariat's Avatar
sclariat
may I ask how you came to the conclusion this vibration is definitely in the front? and if it is surely in the front, have you checked the rims for a build-up of mud or something?
Old Apr 18, 2008 | 12:22 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
One of your wheel weights fall off?
Usually a wheel bearing won't cause a vibration...but more of a moaning/grinding noise that varies with your speed
Old Apr 18, 2008 | 06:49 PM
jnicho6's Avatar
jnicho6
it is more of a groaning noise that sounds loudest between 20 and 30 mph. I took about a 120 mile trip and back and it didnt change at all and i didnt notice any wheel weights missing but that is an easy quick fix that i will check on tommorrow. How expensive or hard is changing the wheel bearing? I've never done one and I try to fix as much as possible if I'm able. Do I need a puller?
Old Apr 18, 2008 | 09:01 PM
sclariat's Avatar
sclariat
rotate your tires and see if it changes the vibration any.
Old Apr 18, 2008 | 11:17 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
How many miles are on your truck?
Depending on the mileage, you might want to go ahead and change the wheel bearings anyways. And I can't find my manual or I'd tell you how to do it...
Superduty ROCKS
Feb 27, 2014 02:38 PM
bluescrew
Oct 27, 2012 09:12 PM
Beau Bo
Feb 27, 2011 08:50 AM
expo54bx
Oct 2, 2010 12:52 PM
53original
Dec 16, 2002 09:47 AM
