Complete front axle re-build
Old Oct 27, 2012 | 12:08 PM
bluescrew's Avatar
bluescrew
Hey guys, has anyone done this? I found my vibration. the front axle shafts have radial play. 4wd still works! I drive almost 100miles a day. I want to tackle this issue!
Also, now that parts guy ed is out of the parts biz, I will be looking at a new power steering pump and steering box this winter. Any ideas?
Old Oct 27, 2012 | 12:56 PM
timf150's Avatar
timf150
ReadHead is the update most are doing for the steering box. Here is a group buy thread going on right now.
https://www.ford-trucks.com/forums/1...g-box-buy.html
other parts guys...both sponsors for FTE
RiffRaff Diesel - Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts
Tousley Ford
Tim M
Old Oct 27, 2012 | 05:06 PM
bluescrew's Avatar
bluescrew
thanks tim!
Old Oct 27, 2012 | 05:46 PM
snknby123's Avatar
snknby123
Bluescrew,
Can you give some more details on your vibration please. I'm fighting vibration in my front end as well. I feel it in the peddle and floor board. Almost like a grinding feeling in the peddle. I need to inspect my wheel bearings but can you give me a description of your vibration and how you found the radial play?
Much thanks!
Stock F250 7.3L PSD 6637 Mod, muffler delete. That's it for now....
Old Oct 27, 2012 | 07:08 PM
bluescrew's Avatar
bluescrew
i doubt you drive like i do. sounds like youve got warped rotors and need a new steady bearing.
Old Oct 27, 2012 | 08:38 PM
srteach's Avatar
srteach
Full rebuild (except ring & pinion, gear bearings) two years ago, wheel to wheel, including bearings and full brakes and ball joints. I have always had grinding in 4wd, so I think it is in the gearing or gear bearings.
Took about 5 hours without knowing what to do. If I did it again, I would pull the hub locking mechanism, and pull the axles first.
If you have a 4wd truck, make sure you get the 4wd abs hubs even if you don't have the 4 wheel abs system and grease those (non-serviceable) hub bearings. I didn't grease them and now have to replace the hub bearings (2 years later). Search for "greasing hub bearings" on this site to find out how and why.
Old Oct 27, 2012 | 09:12 PM
snknby123's Avatar
snknby123
Thanks for the reply
labman1014
Apr 11, 2015 05:17 PM
h20_guy33
Apr 11, 2013 12:42 AM
01f3507.3L
1997 - 2003 F150
Mar 6, 2008 09:15 AM
bczolone
Aug 30, 2006 03:04 PM
2003 Stroke
Aug 5, 2003 02:20 PM
