Axle got hot
Old Apr 14, 2008 | 05:31 PM
rmalottwtes30's Avatar
rmalottwtes30
Axle got hot
When Doing my emergency brakes today we noticed when we pulled out my passenger side axle it looks as if it got a little hot, around where the gasket goes and all the bolts got in. You can tell it got hot because its got that blue looking color.
What may of caused this? We have since then repacked the bearings, replaced the leaky seals, and put in new rear end lube.
Old Apr 14, 2008 | 07:09 PM
srercrcr's Avatar
srercrcr
I thought the bearings swim in diff fluid.
Old Apr 14, 2008 | 07:15 PM
rmalottwtes30
I suspect the differential getting hot was an old issue because when I first bought the truck there was little fluid to come out of the differential so I am suspect no lubricants to the bearings which then made them get hot, but now with the differential full it shouldn't.
Old Apr 14, 2008 | 07:46 PM
84-250's Avatar
84-250
If your diff was run low on fluid, I would change the bearings and races in the hubs. Just because you filled the diff back up doesnt mean there wasnt damage done.
Old Apr 15, 2008 | 02:06 AM
82f3504x4's Avatar
82f3504x4
sure but if it still functions properly you might aswell get as many miles out of it as you can. imo
