Differential I.d.
Old Apr 14, 2008 | 05:10 PM
helenl2's Avatar
helenl2
Differential I.d.
Hi there, I'm new and have spent about a week reading threads. I wanted to learn as much as possible about my truck before asking questions. I would like to find out more about my differential. I know that someone there is very good at breaking down the numbers. 1963 flare side
F25JK412816
122 B F250 81A F 26
G.V.W=7400
HP=114
3600
53
I have found most everything from reading the threads.All my numbers are readable. I have a problem that one or two others have had.My differential seems to be odd. The little plate between the bolts read CITT-BU 2329 5-63 4.38 ON THE AXLE 5 23B 2393 WHERE THE MODEL# looks to be on others has an 80. Would someone help with this Thanks.
Old Apr 14, 2008 | 07:28 PM
garbz2's Avatar
garbz2
Your axle as stock was 26 A spicer with 4.88 gears and 5k rating. so the 3 is actually a 8
rest codes out as
F25 F250
J 223 1v
K Kansas City assembly
412816 Consectuive unit number, built in May 1963
122 Wheel Base Long Bed
B Carribean Turquoise
F250 Model pertains to weight rating.
81 Conventional standard cab
F Four Speed Warner T98A
GVW 7400. maximum registered weight with occupants and load (some state had weight classes for registeration. F250 is a 7400 # where as a F251 is a 4900# rating.
HP 114 gross HP @ 3600 RPM
3600 RPM where maximum HP is produced
53 District Special Order Kansas City (where the truck was ordered)
Garbz
Old Apr 14, 2008 | 08:34 PM
helenl2's Avatar
helenl2
Thanks for the reply. The truck has overloads and they look factory. the truck is very clean and all the # on the door the right side frame and differential are clear. The overloads may exsplain the weight but what does the 80 bottom right stand for. and if is nothing what type rear end is it.other than the over loads the truck is a plane jane. no frills on it at all. SORRY I SEE WHERE YOU SAID IT WAS A SPICER 4.88 . THANKS AGAIN.
ALSO DON'T LET MY USER NAME THROW YOU MY NAME IS JERRY
