Trouble Changing Out Shocks
Old Apr 14, 2008 | 12:47 PM
islander1808's Avatar
islander1808
Hey all-
I will take any help that I can get on this one. I was playing around with the Ex this weekend as my new Shocks (Monroe Reflex) came in on Friday. I was attempting to change them out and started with the front end. I grabbed my ratched and socket set and went to town only to find that nothing I had either standard or metric would fit the nuts holding either the top or bottom shock supports. Any ideas??
Thanks
Old Apr 14, 2008 | 02:17 PM
BobBarry's Avatar
BobBarry
Originally Posted by islander1808
Hey all-
Thanks
I put some details of my shock install in my gallery; from the factory the front uses an 18mm nut on the top mount, and a 15mm and 21mm(?) for the bottom bolt and nut. Odd that those wouldn't fit on yours?
Old Apr 14, 2008 | 03:08 PM
islander1808
An 18mm is not a standard size that is included in most sets. I will have to pick that one up. I don't think that I have a 21either. I have a 17 & 19... go figure. I just checked out your gallery and great job on the photos. Any tips for people without air tools???
Old Apr 14, 2008 | 05:42 PM
FordCrusherGT's Avatar
FordCrusherGT
I did my shocks in about an hour in my driveway. It is extremely easy to do. I didn't use any air tools, just standard ratchets. I used a cheater bar to break the bolts loose for the front ones, but that's it.
Once you get the sockets that fit you should be fine.
Old Apr 14, 2008 | 06:28 PM
islander1808
Good to hear. I will be stopping by home depot on the way home and picking up what I need!!
Old Apr 15, 2008 | 12:24 AM
BobBarry's Avatar
BobBarry
X2 on the cheater-bar. The air-tools are for speed, not power. I did have to use a breaker-bar on the passenger-side lower shock-bolt.
Also, hold the nut in place and try to turn out the bolt, rather than the other way around.
And use anti-seize to protect against corrosion.
Old Apr 15, 2008 | 09:20 AM
islander1808
With regards to corrosion... I don't think that I will have to worry about it out here. I live in Fresno, CA... it is a desert and when we do go up in the mountains, they don't salt like they do in the midwest. I can't remember the last car that I saw (under 40 years old) that had rust on it. If I were at home (Iowa) I would be a little more precautious. Thanks for the tips guys!!!
