Speedo PRoblems
Old Apr 14, 2008 | 12:11 PM
Why Not's Avatar
Why Not
Speedo PRoblems
I am having problems with my speedo in my truck I just purchased. The speedo is jumping while you are driving down the road. I have replaced the speed sensor on the rear diff. I have checked the wiring from the rear diff to the frame, no problems othe than the plug. I replaced the pig tail wiring to the speed sensor because of a bad plug on the wiring harness. The last owner replaced the instrument cluster thinking that would fix the problem and it did not.
I guess that I am down to pulling the diff cover and checking the tone ring? Is there something that I am missing? Thanks for the help in advance.
Why Not (Chris)
Old Apr 14, 2008 | 01:39 PM
97 HD's Avatar
97 HD
good luck and post if you figure it out. I have the same problems with mine and havent been able to fix it.
