Wiring 7-pin trailer connector on 2000 Expy.
Old May 13, 2008 | 09:57 AM
chivas72's Avatar
chivas72
Same deal here and was hoping for some enlightment
i have the brake controler and tekonsha harness
found that conector under the dash
i also found the 4 pin harness by the rear bumper
i wish i could use the harness i bought instead of wiring all the way back but i can't find the the end points in the rear to hook up the female conector for the 7 pin
pics ? ? ? ? ? ?
Old May 20, 2008 | 06:15 PM
cbradford's Avatar
cbradford
Just check out etrailer.com and you will find all you want to know about wiring for a 7pin trailer connector, I tow a 28' Travel Trailer
Old May 20, 2008 | 07:37 PM
fred_79f250's Avatar
fred_79f250
i wish i could use the harness i bought instead of wiring all the way back but i can't find the the end points in the rear to hook up the female conector for the 7 pin...
You mean you've got the stock 4-pin on the rear of the truck and bought the 7-pin harness to replace it?
Lie on your back under the rear bumper, driver side, you'll see the wire from the 4-pin connector come out from the bumper. It should run to the inside of the driver side frame rail just ~1-foot forward. The connector is held to the side of the frame rail by a plastic plug. Your new 7-pin harness plugs into that.
TomDillard
May 10, 2014 12:04 AM
talonpilot
2009 - 2014 F150
Feb 19, 2014 07:24 PM
54 Oldsman
Electrical Systems/Wiring
Apr 6, 2003 12:09 AM
flyloki
Aug 28, 2002 06:26 PM
