352/360 swap
Old Apr 13, 2008 | 08:45 PM
jackndelphine's Avatar
jackndelphine
352/360 swap
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>Hi everyone, I just had a couple of questions, I recently found out that my 74 highboy has a dead 360 in it. It was smoking and had no compression in one of the cylinders, so I found a guy with 2 352s that wanted to swap me for a 302 I had, he said one engine smoked and the other was fine. So I go the engines today and the good engine seems to be missing the flex plate, so I was wondering if the one from my 74 360 would work. The reason I am asking is because the 352 doesnt have a harmonic balancer, but I heard they are balanced through the main pulley. If I use the flexplate from my 360 am I going to have to also use the balancer from it as well? Is there anything else I could swap tform my 360 if need be, beside the obvious, also, do 352 have any bad traits I should be on the lookout for? Thanks in advance, Jack
</TD></TR></TBODY></TABLE>
Old Apr 13, 2008 | 09:28 PM
Bear 45/70's Avatar
Bear 45/70
All the parts off the 360 will work on the 352. A 360 is just a .050" bored over 352.
