Rear diff. help
Old Apr 13, 2008 | 08:32 PM
crashnburk's Avatar
crashnburk
Rear diff. help
Can anyone help decipher the numbers on the tab of the rear diff.
Here it is. s 411 b
0 10 2 oko6
I think there is one more number at the start of each row that is partially covered the the bolt.
Also what do I need to do to lower my lift from 10" to 8 or 6?
My wife had surgery on her knee and now has a very hard time getting in it.
Thanks in advance guys
Old Apr 13, 2008 | 10:57 PM
i eat hybrids's Avatar
i eat hybrids
Swap out the leaf springs or blocks in the rear and swap out hte leaf springs in the front. If your looking for your rear gear ratio, its on the drivers door.
Old Apr 13, 2008 | 11:01 PM
crashnburk's Avatar
crashnburk
Diff Help
Thanks for the info. As far as the gear diff. goes, I was trying to figure out if the gear diff. was changed by the previous owner and if so to what? The stock was 3.73
Old Apr 13, 2008 | 11:03 PM
i eat hybrids
Well, i see that you have a lifted truck. 1 way that you can tell what kind of rear end gears you have is by your RPM's at 65 mph. BUT tires size plays a factor. What is ur tire size?
Old Apr 13, 2008 | 11:05 PM
crashnburk's Avatar
crashnburk
Tire Size
They are 37 x 12.50 r18 LT's
Old Apr 13, 2008 | 11:14 PM
i eat hybrids
And your rpms at 65?
Old Apr 13, 2008 | 11:33 PM
OverEngineer's Avatar
OverEngineer
Your truck may also have spring hangers that could go back to stock. I have a spare set of stock ones if you need them. No charge, free for the taking
Old Apr 19, 2008 | 06:28 PM
crashnburk's Avatar
crashnburk
Rpm @ 65
Tire Size:
37 x 12.50 r18 LT's
RPM'S @ 65 is 2780
Old Apr 19, 2008 | 08:50 PM
Monsta's Avatar
Monsta
Sit. Stay.
WHAAAAAAAAAAA?????
Are you in OD at that RPM!? If you are only in third then it appears you may have 4.56's.
If you are in OD then you have 6.75's...a nonexistent gear ratio....or you have problems elsewhere.
Old Apr 20, 2008 | 12:54 AM
crashnburk's Avatar
crashnburk
Gears
Yeah I am in OD. Thanks for all your help.
Old Apr 20, 2008 | 01:28 AM
Monsta's Avatar
Monsta
Sit. Stay.
How can that be!?
With 4.56's in OD (.72) cruising at 65mph on your 37's, you should be turning 1938 (+/-). in 3rd (OD locked out 1:1) then you'd be at 2692.
Even if you had 5.13's you only be at 2180 in OD. They don't get much steeper than that or the pinion would be too weak (small).
Something has to be off somewhere. It may be your speedo or even your tach. Do you have access to a GPS to verify your speed?
Old Apr 20, 2008 | 02:30 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Wow that sounds Wayyyyyyyy off
Old Apr 20, 2008 | 06:43 PM
crashnburk's Avatar
crashnburk
Gears
I'll be driving it tomorrow and re-try it and let you know. The vehicle doesn't feel like 4:56's are in it. I think it still has stock 3:73's at least that's how it feels when just starting from a stopped postion. When I have my 33' travel trailer connected it barely pulls it from a stopped positon.
