Swap out the leaf springs or blocks in the rear and swap out hte leaf springs in the front. If your looking for your rear gear ratio, its on the drivers door.
Thanks for the info. As far as the gear diff. goes, I was trying to figure out if the gear diff. was changed by the previous owner and if so to what? The stock was 3.73
Well, i see that you have a lifted truck. 1 way that you can tell what kind of rear end gears you have is by your RPM's at 65 mph. BUT tires size plays a factor. What is ur tire size?
I'll be driving it tomorrow and re-try it and let you know. The vehicle doesn't feel like 4:56's are in it. I think it still has stock 3:73's at least that's how it feels when just starting from a stopped postion. When I have my 33' travel trailer connected it barely pulls it from a stopped positon.
