UNhook to weld?
Old Apr 13, 2008 | 07:29 PM
2 stroke man's Avatar
2 stroke man
UNhook to weld?
i have a 97 powerstroke and was wondering-when properly grounded do i really need to unhook to weld to my trailer? i have heard that it will burn up the alternator
Old Apr 13, 2008 | 07:34 PM
Toyman's Avatar
Toyman
Safest to unhook the trailer. There are a ton of sensitive electronics on the new vehicle, the welder could surge and pop something. Burned up a magneto on a race truck cuz we were in a hurry to get it welded and back out to play.
Toyman
Old Apr 13, 2008 | 07:37 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Don't think it would do the electronics on the truck any good.
unrulee's Avatar
unrulee
What toyman said. I work in a OTR truck/trailer shop. It's always a good idea to unhook the truck form the trailer when welding.
Have I ever seen anything get fried by not unhooking.........no, but I've heard stories.......expensive electronic stories. So for peace of mind if you need to weld on the trailer take a couple of minutes and unhook. Your wallet may thank you.
Old Apr 13, 2008 | 07:45 PM
Diesel Man 03's Avatar
Diesel Man 03
The computer in your truck could possibly get fried, I would unhook.
Old Apr 13, 2008 | 07:47 PM
gbadgley's Avatar
gbadgley
Not a bad idea to clamp a zapper on the battery either. Greg
Old Apr 14, 2008 | 01:18 PM
okfarrier's Avatar
okfarrier
They recommend it always,but I tend do be lazy some days and dont unhook mine.Though I make sure the ground is as close to where you are welding as possible.
Old Apr 14, 2008 | 02:33 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
So what about welding on the truck itself??? Kind of difficult to remove all the electronic "stuff" prior to welding.
Old Apr 14, 2008 | 04:01 PM
Toyman's Avatar
Toyman
Welding on the truck alone you need to unhook the battery negative cable. Then you should be fine.
Toyman
Old Apr 15, 2008 | 08:35 AM
BobsF350's Avatar
BobsF350
Use a chain to ground the area your welding.Hang the chain from within a foot or so of where your welding to the ground.electronics are an issue as well as other things.
I build headers and dont like to do it with a complete motor in the car but i will.You can weld the ring together at the ring gap and tack them to the cylinder walls.If not very well grounded.
Old Apr 15, 2008 | 03:17 PM
dkf's Avatar
dkf
FWIW both exhaust shops I've had my trucks to over the years have NEVER unhooked the battery when welding on the exhaust. Is it a good idea to disconnect the battery or unhook the trailer while welding......Yes. Will it hurt anything.....if you have a good ground close to where your welding probably not. I've welded on my SD exhaust already and forgot to unhook the battery, no problems.
Old Apr 16, 2008 | 11:05 AM
thorian's Avatar
thorian
My little brother got his Apexi Fuel computer fried out because dad didn't unhook his battery before welding the exhaust up. Lucky for him that it took the hit instead of his ECU as he was able to just unhook it and plug the wiring harness back in to the factory computer for stock fuel settings to get it going around until the replacement unit came in.
