fan hitting radiator help
Old Apr 13, 2008 | 11:42 AM
rickeylipham's Avatar
rickeylipham
Question fan hitting radiator help
1993 f150 4X4 4.9 When I take off from a dead stop hard the fan rubs the radiator. I replaced the right motor mount and the left appears ok. What could cause the fan to hit the radiator only when accelarating??? any help appreciated...
Old Apr 13, 2008 | 11:50 AM
khadma's Avatar
khadma
Carpenter Local 745
Were any of the parts replaced in the past?
Water pump - may have longer impeller shaft
Radiator - may have more cores than original
Fan - maybe blades are bent or cracked
Fan clutch - maybe thinker than stock.
Usually, in a stock configuration, there is more than enough space between the fan and radiator.
Old Apr 13, 2008 | 12:36 PM
cpettymore7777's Avatar
cpettymore7777
you can check the blades and see if one had more give than the other
Old Apr 13, 2008 | 12:49 PM
bad96's Avatar
bad96
first thing id check would to be if the radiator is secure and the shroud
if ya take off from a dead stop anything loose would move back!!!!!!!!
Old Apr 13, 2008 | 07:01 PM
c_rossman's Avatar
c_rossman
My 87 rubs on the shroud when I am going over rough terrain. I believe it is the front cab mount that is bad on mine.
Old Apr 13, 2008 | 08:21 PM
mhg's Avatar
mhg
check all mounts
engine, body and transmission
lock the parking brake and slowly apply power with hood up
watch for movement in the angine and body
engine rolls over is engine mounts
if it dips down in front then check the trans mount
if the rad. moves look to your body mounts
Old Apr 13, 2008 | 10:01 PM
Bob Rudd's Avatar
Bob Rudd
Radiator supports were known for rotting out like my '95 did to the point where the hood, grille, and both fenders are floating instead of being secured to the frame rails via the rad support...check by throwing up the hood rather hard and watching both fenders when the hood hits the stops...if they move, you need to replace your radiator support...
bismic
Mar 9, 2022 09:20 AM
'50'sFever
Ford Truck Parts for Sale
Sep 27, 2014 05:25 AM
Steel Toy
Vehicles for Sale
May 9, 2014 07:46 AM
jmh944911
Mar 13, 2014 12:40 PM
Biggoomba
1947 and Older Ford Trucks
41
Nov 27, 2013 07:07 PM
