Flex plate location
Old Apr 22, 2002 | 05:12 AM
goodfoot's Avatar
goodfoot
Flex plate location
I'm putting a rebuilt motor in my 74. The motor has a "heavy weighted" harmonic balancer in place. I've got to install my matching weighted flex plate on the rear of the crank. How do I mount the flex plate to correspond to the harmonic balancer so I don't end up with a vibration? Thanks, Goodfoot
Old Apr 22, 2002 | 07:31 AM
swirk's Avatar
swirk
Flex plate location
The bolt holes will only line up in one position. I had the same question about installing a flywheel on a 1995 351w. Someone said that they only line up in one place. Sure enough the bolts only line up perfectly in one position.
Old Apr 23, 2002 | 04:38 AM
goodfoot's Avatar
goodfoot
Flex plate location
Thanks for the tip. It should be running by the weekend. Goodfoot
Old Apr 23, 2002 | 04:53 AM
goodfoot's Avatar
goodfoot
Flex plate location
