Harmonic Balancer
Old Mar 10, 2002 | 09:59 PM
Shannonm1's Avatar
Shannonm1
Post Harmonic Balancer
I have a '78 351W that needs a harmonic balancer. What all years or motors have one that would fit? Thanks in advance.
Shannon
Old Mar 11, 2002 | 11:16 AM
airharley's Avatar
airharley
Harmonic Balancer
If I am not mistaken you can interchange all years the 351W was made. It's the 302 eninge that had the change in weight.
Old Apr 11, 2002 | 10:24 PM
JMR's Avatar
JMR
Harmonic Balancer
I need one for a '68 302. what years will interchange.
Old Apr 12, 2002 | 12:09 AM
Brian's Avatar
Brian
Harmonic Balancer
The small block performance book by Isacc Martin says any damper before 1981 will fit. The change from 28 oz to 50 oz was made then.
Brian
Old Apr 14, 2002 | 05:59 PM
JMR's Avatar
JMR
Harmonic Balancer
I found one at a local yard that matched my old one , but I don't know if either are correct. I read somewhere that the 60's had three bolts instead of four holding the pulley. And my TDC mark does'nt my pointer....my timing pointer is on the driver's side the motors Ive seen lately are on the passenger side.. Can somebody decipher---C80E-6015-A
thanks,john
Old Apr 19, 2002 | 04:47 PM
m79f100's Avatar
m79f100
the 'c'stands for 60s'the#8 it would be a 1968 302 engine,the 6015,is the # for a 302-A-stands for change level code.i also have a 68 302,my numbers were not as easy,were the letter 'E' is that stands for engine,on my block there is the letter 'M' were the 'E'should be?
Old Apr 23, 2002 | 04:53 AM
goodfoot's Avatar
goodfoot
Harmonic Balancer
Either the 28 oz. or 50 oz. will work. The key is to make sure both the harmonic balancer and the flex plate match each other. In other words a 28 oz. flex plates needs a 28 oz. harmonic balancer. There are no "Good Viberations".
Old Apr 23, 2002 | 10:55 AM
loudfords's Avatar
loudfords
Harmonic Balancer
