4" Lift Install
Old Apr 12, 2008 | 07:52 PM
RussB's Avatar
RussB
4" Lift Install
So... I'm installing my procomp lift on monday... Is there any tips you guys can share ??? I've heard getting the front spring bolts out is a PITA. Has anyone taking the front spring out that has first hand knowledge of this issue ???
Old Apr 12, 2008 | 08:00 PM
DCSpecial's Avatar
DCSpecial
Nope, not too hard with air tools.
You need big enough jack stands to support the frame up high enough to lower the axle and install the new springs.
You need a pitman arm puller big enough for the pitman arm and a big enough socket, 30mm socket for the trac bar. Trac bar bolts need to be torqued to 369 ft/lbs.
A helper is nice to have.
Use loctite on the pitman arm nut.
That's the main stuff that comes to mind. Pretty straight forward install.
Old Apr 12, 2008 | 08:01 PM
megawatt00's Avatar
megawatt00
The last time that i installed a lift the kit came with new u-bolts. I just fired up the torch and cut off the old u-joints.
Old Apr 12, 2008 | 08:16 PM
RussB's Avatar
RussB
My friend up the road restores and builds hot rods and has a body shop.. He's got all the tools that a guy could think of... sometimes 2 and 3 of each.. lol I just called him and he's pretty sure he has a pitman arm puller !!
I'll be doing the install there
Old Apr 12, 2008 | 08:21 PM
DCSpecial's Avatar
DCSpecial
Just a FYI, lots of pitman arm pullers don't fit the SD pitman arm.....but on most of them you can use a die grinder to open it up a little bit to fit over it.
Old Apr 12, 2008 | 08:27 PM
RussB's Avatar
RussB
Thanks for the info Dan... I'll see what happens on monday morning and let you know how it turned out ...
Thanks again for the info.... Reps sent !
Correction... won't let me send you them.. I already sent you some for your help with the rims..
Old Apr 12, 2008 | 09:26 PM
StrokeR_7.3's Avatar
StrokeR_7.3
Russ,
Good Luck on your install i can't wait to see how see looks with them extra inches.
Make sure to post plenty of pics
and keep us updated on your progress...
Paul
Old Apr 13, 2008 | 11:08 AM
Ford79's Avatar
Ford79
This is the pitman arm puller I ordered from my local auto parts store.
On a related note, does the front bumper have to come off to install the springs or can it be done without?
Good luck with the install.
Old Apr 13, 2008 | 11:26 AM
DCSpecial's Avatar
DCSpecial
You can do it with the bumper on.
But, it's easier and gives you more space with the bumper off. Only takes a few minutes to remove the front bumper on the SDs anyway.
Old Apr 13, 2008 | 12:50 PM
Ford79's Avatar
Ford79
Thanks again DC. I'm all about doing things the easy way, so the bumper will come off.
I tried giving you reps for all the help but am told I need to spread them around a little first.
Old Apr 13, 2008 | 06:57 PM
DCSpecial's Avatar
DCSpecial
Glad to help.
Just 6 bolts hold the bumper on your 2001. 2 by each tow hook and one in each wheel well. Remove them, slide it out a little bit to disconnect fogs, block heater, etc.. and then remove. If you have someone to hold it in the middle while you do this it makes it easier.
Old Apr 13, 2008 | 10:48 PM
RussB's Avatar
RussB
Taking off my front bumper is a bit of a chore.. All my lights on there and wiring and front receiver etc.... I'm going to try and attempt it with it on first... If I HAVE to... I'll take it off... I'll be starting tomorrow am... YeeeeHawwww ! Gave myself a hernia a couple of weeks ago and I'm in quite a lot of pain right now.. So it might take a little longer than normal !! Hopefully won't be to hard of a job !
Old Apr 13, 2008 | 11:08 PM
nhill2090's Avatar
nhill2090
I think you guys pretty much got it covered.
The hardest part of my lift install was the pitman arm, PITA. If all else fails, aid your puller with a torch and a BFH.
Also, my rear shocks bottom mount bolts were rusted into the metal sleeve of the shock bushing, but thats nothing a grinder cant fix
Old Apr 13, 2008 | 11:15 PM
OverEngineer's Avatar
OverEngineer
It will be fine. Our suspension is far simpler than an IFS. Now... If you're willing to use bushwacker's cut out flares, you will be able to mount 40" tires on that beast... That's HOT
Old Apr 13, 2008 | 11:20 PM
RussB's Avatar
RussB
So these pitman arms..... the aren't hard to put back on are they.... They give you a new one in the kit !! Are they just a bugger to get off ????
