ordered my 6637 air filter
Old Apr 15, 2008 | 10:50 AM
Neal 97 250's Avatar
Neal 97 250
can you say kold kitty?
Old Apr 15, 2008 | 12:46 PM
884x4broncoII's Avatar
884x4broncoII
well i got the filter installed, the old box came out easy, less than 5 mins. i used a 3 inch 45* sewer pipe elbow with the flared ends, measured 4 inch outside diameter, i didn't have time to run allover town looking for an elbow. i grabbed my dremel with a flapper wheel attachment and smoothed the ridge on the inside similar to how you would gasket match a head/manifold so hopefully it wont cause any turbulence. but its only temporary till i find an 4 inch without the flared ends or some place that has the 4 inch exhaust elbow. like i said i don't have time to run all over town right now and this is what they had at the mac's hardware up the street from the auto parts store.
Old Apr 15, 2008 | 01:02 PM
Neal 97 250
Sounds like you got it done fine. That way should work goo dfor you. Sound any different?
Old Apr 16, 2008 | 03:52 AM
884x4broncoII
i can hear the turbo spool a little better and seems to spool a little faster with the cat removed. if i gain .5 mpg it will all pay for itself in the next 2 months seems how next month i have over 4000 miles of towing to do.
do you guys think im fine with the 3 inch 45 it has the built in couplings so the outside diameter on the ends is 4 inch so it clamps in nice but the center of the bend is 3 inch inside diameter, i dremeled down the ridge on the end of the coupling section and faded into the center to avoid turbulence. i don't want to add an restriction point. i don't have time at this moment to search for anything better, if you guys all think im fine with the 3 inch 45 ill just leave it in there permently. i suppose the crack case ventaliation peice in the air intake is probably just as restrictive as my 3 inch elbow. although i suppose even though i smoothed the ridges on the elbow it could still cause some turbulence going from 4 inch to 3 inch to 4 inch to three inch (pvc section) and then into the turbo
Old Apr 16, 2008 | 08:14 AM
Neal 97 250
You should be fine with that setup. Now if you were sled pullin' or something like that I would reconsider.
Old Apr 16, 2008 | 10:22 AM
secondarychaos's Avatar
secondarychaos
Ya, for the most part, you cant create much more turbulence than that stock accordian that's under the hood. Best way to have good, laminar flow would be replacing that with pipe, and having smooth bends. But honestly, For the Extra $40 you might spend on that, you'd only pick up a few CFM. I'd leave it just like you have it.
Old Apr 16, 2008 | 12:11 PM
884x4broncoII
what size is the turbo inlet?
Old Apr 16, 2008 | 07:10 PM
444dieselrod's Avatar
444dieselrod
2.5" I think. it might be 3" I have never measured it.
intake pictures from trucks photos on webshots
I ditched the CCV housing, which requires routing it under the truck to atmosphere, and made my own intake all the way to the turbo.
Diesle Rod
Old Apr 18, 2008 | 05:20 AM
884x4broncoII
well now that i got my belt/tensioner problem fixed i noticed the turbo sings a beautiful song with the 6637 and cat delete i seem to have picked up about 2 mpg been threw a 2 1/4 tank in the last few days (lots of driving and lots of towing)
Old Apr 18, 2008 | 10:13 AM
secondarychaos
2 mpg? wow! your stock filter must have been REALLY clogged!
Old Apr 18, 2008 | 01:35 PM
884x4broncoII
the airflow meater was sucked about 1/4 of the way in on the stock air box
Old Apr 18, 2008 | 01:56 PM
884x4broncoII
here is a pic of my 6637 filter installed
Old Apr 18, 2008 | 02:03 PM
  #28
Neal 97 250
Actually, that looks pretty good.
Old Apr 18, 2008 | 03:49 PM
  #29
jimwilsonmasonry's Avatar
jimwilsonmasonry
looks good to me to
pullinair
19
Oct 5, 2008 09:56 PM
outdoormaniac
38
Feb 9, 2008 11:15 PM
Corner Gas
21
Nov 1, 2007 09:31 PM
mybigredford
15
Apr 26, 2007 07:25 AM
erik_bishop
Sep 20, 2006 08:15 AM
