Sponsored by: Real Truck
Mag-Hytec diff cover & Autometer sending unit
Old Apr 14, 2008 | 07:25 AM
Gage2502's Avatar
Gage2502
One more question what size drill bit do I need for a tap that is 1/8"-27 NPT. I was at Lowe's and they have the tap but no drill bit for it.
Thanks ~Gage~
Old Apr 14, 2008 | 09:15 AM
Fat Diesel's Avatar
Fat Diesel
You want to use a Q size drill bit. It's diameter is 0.332", but in a pinch you could probably get away with using a 21/64" which measures out to 0.3281".
Old Apr 14, 2008 | 10:53 AM
Gage2502's Avatar
Gage2502
Thanks Fat Diesel, I do have a 21/64" bit so I will use that.
~Gage~
Old Apr 14, 2008 | 10:59 AM
Fat Diesel's Avatar
Fat Diesel
Cool. Good luck. The tap might feel a bit tight since the minor diameter (inside of the threads) is 4 thou smaller than a Q drill, but a human hair is like 3 thou so it's really not that much. I routed the wire up and used black silicone to adhere it to the housing in a couple of spots then zip tied it to the brake line or ABS sensor wire, I can't remember off the top of my head.
Old Apr 14, 2008 | 06:36 PM
ReAX's Avatar
ReAX
Originally Posted by thedaddycat
ReAX,
I might be wrong about this, but I thought NPT stood for National Pipe Tapered as opposed to NPS(National Pipe Straight). You are correct in that NPT does in fact taper which helps make a good seal as the threads get tighter the deeper you get. It's kind of like taps. There are starter taps, plug taps and bottoming taps and each has a different taper to it.
It's quite possible, I have never heard of or seen NPS. My grandfathers called it nation pipe thread, so that's where I get it.
Old Apr 14, 2008 | 09:34 PM
Gage2502's Avatar
Gage2502
So I now have the right tap 1/8" 27NPT Taper tap and I also have the bit 21/64.
I will drill and tap the cover this week and let you know how it came out.
The Taper Tap is the right one right?
Thanks again ~Gage~
Old Apr 14, 2008 | 09:52 PM
thedaddycat's Avatar
thedaddycat
Take a look at the right side of this chart:
American Standard Pipe Dimensions -- Technical Notes
If you look at the bottom, it shows that for NPT with reamer you use a reamer with a taper of 3/4" per foot. To get an idea of what that is, take two rulers and touch the ends together and spread the other ends 3/4" apart. It might not look like much taper over the short length of a small tap, but you will get the idea.
Old Apr 14, 2008 | 10:05 PM
Gage2502's Avatar
Gage2502
OK I see what you meen, also what would be best to use sealant compound or Teflon tape I have both. Thanks again for your time and help ~Gage~
Old Apr 14, 2008 | 10:29 PM
thedaddycat
Use both if you have them already. Tape it first, then some paste. Remember that you will need to have electrical contact but if you tighten it up good that should not be a problem.
Old Apr 14, 2008 | 10:57 PM
ReAX's Avatar
ReAX
I'd steer clear of tef-tape since you need good contact and I suspect that tef-tape is non-conductive. At least we used it on steel scuba tanks and brass valves to stop corrosion, I think was partially the pressure but we were also concerned about electrolysis.
PTE pipe dopes are probably the same, so read your labels.
Old Apr 15, 2008 | 06:50 AM
Gage2502's Avatar
Gage2502
Thanks again guys for all your help.
~Gage~
Old Apr 15, 2008 | 08:32 PM
Gage2502's Avatar
Gage2502
Well I did it=) it turned out great took about 45min I dont know if thats a long time.
I will install it tomorrow.
Thanks again guys for everything.
~Gage~
Old Apr 15, 2008 | 10:08 PM
  #28
ReAX's Avatar
ReAX
Not bad actually, especially if this was your first time. Precision on these fittings are the only way to go.
Old Apr 16, 2008 | 08:16 PM
  #29
Gage2502's Avatar
Gage2502
I just installed the rear cover today and it went well took about 1.5hrs to install and fill.
Thanks for all you help guys.
Also does anyone have the front cover on their trucks? I have the Mag-Hytec front cover and hope to install it tomorrow.
~Gage~
Old Apr 16, 2008 | 11:36 PM
  #30
thedaddycat
Yes, I have M-H covers on both diffs and a M-H tranny pan. I have temp probes in all three along with another one in the block for coolant temp. I wired them through a selector switch so I can read any of them on the tranny temp gage. All three covers and the block plug adapter are threaded 1/8" NPT, as are the temp probes. I did not have to drill or tap anything.
