Sponsored by: Real Truck
5.4 Cold starting problems
Old Apr 11, 2008 | 09:00 PM
99_F250_SD's Avatar
99_F250_SD
I have a 1999 Ford f-250 Superduty 5.4 with 124,000 miles and it doesnt like to start in the morning. When you crank it, it idles at 500 rpm and stays that way till it warms up, some times it dies on me, what might be the problem?
Old Apr 11, 2008 | 09:32 PM
elmo8641's Avatar
elmo8641
check the engine coolant temp sensor with a scanner before start up. if it is hotter or colder than it is outside then that would be your problem.
Old Apr 11, 2008 | 10:15 PM
redford's Avatar
redford
FTE Leadership Emeritus
Check your Idle Air Control Valve (IAC), it probably needs cleaning or replacement.
Old Apr 11, 2008 | 10:21 PM
fyrmnk1's Avatar
fyrmnk1
Mine's done the same thing a few times on really cold mornings the last couple winters. Mine will usually straighten out after a few seconds if I give just a touch of throttle while starting it. I have 109,000. It does fine all the other times so I haven't looked into it. However, I will now check my IAC.
Old Apr 11, 2008 | 11:33 PM
Jojiggler's Avatar
Jojiggler
I had a 99 f150 5.4 with the same/similar problem (or atleast it sounds). Start and die over and over. If i remember correct it was my MAF sensor. I cleaned the IAC in hopes of a fix before i took it in to the wallet weight loss center.
Old Apr 12, 2008 | 10:21 PM
99_F250_SD's Avatar
99_F250_SD
My truck also has a sloppy idle, like it seems to fire one side then the other its not smooth, it will start to rock my truck from side to side. Would a mass airflow sensor also cause this problem?
