Sponsored by: Kumho
compatible shocks
Old Apr 11, 2008 | 08:03 PM
ajm859830's Avatar
ajm859830
compatible shocks
I have a 99 f150 w/ 4.2 2wd with the fabtech 3.5" control arm lift. The rear shocks are fabtech fts7236 specs are below. I was wondering if anyone knows of a shock that would work/fit just as well such as a rancho or something I can get locally w/o ordering. The rear block is 2" (factory?).
extended 24.8 and collapsed 14.6
Old Apr 27, 2008 | 06:20 PM
ReAX's Avatar
ReAX
If you go to your local shop, Rancho and most of the other shock companies list their shocks by spec in their catalogs. It's also available online, but I found it to be easier to cross reference when you have a half dozen catalogs lay out over a counter. Close is good enough for shocks.
Old Apr 27, 2008 | 06:26 PM
khadma's Avatar
khadma
Carpenter Local 745
Most "SHARP" countersales people will ask you if you truck is lifted and/or dropped.
Tell them what you just told us and you should be fine.
Rancho, Bilstein(sponsor) are good starting points. Procomp also sells Rancho like shocks at an affordable price.
I put Procomps on a while back and they are still firm and are holding up well.
I plan to put Bilsteins on all my trucks when the time arises.
Old Apr 27, 2008 | 06:47 PM
ReAX's Avatar
ReAX
Perhaps because I've been the sharp counter person, I'd think there are that many that would qualify. Most of the shock books I've been in say 0-4" lift and 4+, the average counter man can get confused, so pick which and tell him what he needs to come to your shock, or just show up with a part number.
Old Apr 29, 2008 | 05:58 PM
rebocardo's Avatar
rebocardo
Download the Ranchero catalog, spec. what you need, then go to Advance Auto and give them the number and if not in stock they can have it there the next day. That is what I do.
Fatbob316tx
Offroad & 4x4
Sep 12, 2017 02:21 PM
Blakshukvw
Mar 5, 2017 05:55 PM
Blakshukvw
Mar 2, 2017 08:41 PM
cbzdel
Feb 27, 2012 08:05 PM
riggz
Jul 13, 2007 03:54 PM
