Sponsored by: Real Truck
Do I have Diff Problems?
Old Apr 11, 2008 | 07:34 PM
sealer700's Avatar
sealer700
a Few weeks ago, I was stuck in the snow. Got out to shovel and back tires on hard pack snow front drivers tire on Ice and pass only 1 spinning. Not hardly any snow under truck at all. Might I have rear end problems? 4 hi or low front pass only 1 spinning. Its been fine since but I havent been stuck since. This was the second time I got stuck when I shouldnt have been. Same front tire doing all the work that time also? 1 Wheel Drive??
Old Apr 11, 2008 | 07:37 PM
sealer700's Avatar
sealer700
sorry. truck is an 06 f250 crew diesel fx4 3.73 ls
Old Apr 11, 2008 | 07:54 PM
mstiles19's Avatar
mstiles19
you have open diffs...thats normal my truck does the same thing in the sloppy stuff. Its normal! haha so your OK!
Old Apr 11, 2008 | 07:56 PM
3000 FPS's Avatar
3000 FPS
Are you saying the rear wheels never would spin even when in 4 wheel drive Hi or Low?
If the rear wheels never spin I would suspect transfer case not the rear end.
Old Apr 11, 2008 | 07:57 PM
sealer700's Avatar
sealer700
Im suppose to have limited slip in the rear?
Old Apr 11, 2008 | 07:59 PM
sealer700's Avatar
sealer700
no the rear wheels did not spin at all. Also its sometimes is very slow going into 4x4. I usually let off gas, switch button, then back on gas. then slam into 4x4
Old Apr 11, 2008 | 08:33 PM
mstiles19's Avatar
mstiles19
oopppppsss......i miss read your post. I agree with 300FPS, i think it may be a problem with your transfer case.
Old Apr 12, 2008 | 02:49 AM
GregsSD's Avatar
GregsSD
Even if you don't have limited slip in the rear, one rear wheel should be spinning!
Does the truck work when in 2wd?
