2000 7.3 codes
Old Apr 12, 2008 | 10:13 PM
clintbonnie's Avatar
clintbonnie
Originally Posted by F350-6
Can you feel / tell anyhting that's wrong? The whole purpose of a chip / tuner is to make things run "above desired level"
No.. everything runs super..just like a superduty should.. I guess i need get the "Big Oil".. I don't believe my Diablo Sport programmer is going to make the injector pump run harder than designed.. Only problem I have ever had with my engine since new (9 years) was both the damn 9 pin UVC connectors came loose last year. Fixed it and it has been running great ever since..
Old Apr 13, 2008 | 08:18 AM
F350-6's Avatar
F350-6
I think you're probably fine with what you have. Your Diablo is just increasing the Injection Control Pressure. Turning up the pressure means more fuel for the injectors. More fuel = more power. You'll probably get the same code even with big oil.
