Balljoints?
Old Apr 11, 2008 | 01:12 PM
Rambo76's Avatar
Rambo76
Balljoints?
How can I tell if my balljoint on my 76 is going bad? My past experience's have been balljoints squeeling. (like a sqweeky bed sound) I have a clickin/ knocking sound when turning on my 76 and my pass side universal is all but shot on the pass side wear the noise is coming from. My question is how can I tell if the balljoint is bad also?
Old Apr 11, 2008 | 01:35 PM
vic_v8's Avatar
vic_v8
get the axle/tire off the ground, put your hands at the 12 and 6 o'clock positions, and check for free play
Old Apr 11, 2008 | 01:53 PM
Rambo76's Avatar
Rambo76
Thanks.
If there isn't any play the balljoint should be good right?
Old Apr 11, 2008 | 02:01 PM
vic_v8's Avatar
vic_v8
should be, also at the 9 and 3 check the tie rods with the steering wheel locked.
Old Apr 12, 2008 | 05:27 AM
trinogt's Avatar
trinogt
You should check for wear in your tie rod ends as well, and for degraded bushings in the radius arm bushings. Anywhere that you find moving parts. Sometimes having someone in the front seat turning the wheel back and forth while you closely look at steering components can reveal the problem.
Old Apr 12, 2008 | 06:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Clicking sound = the needle bearings inside the U-Joint cups are worn/missing.
Ford p/n: D3TZ3249A .. U-Joint / Spicer part number: 5297X
Ford suggested retail price: $44.42 / ftepartsguy.com price: $31.98
Clicking: It could also be a sign the 4WD hubs need attention.
Old Apr 13, 2008 | 02:47 PM
Rambo76's Avatar
Rambo76
Thanks guys. Some very good info here. I just want to make sure that if I tear into it I replace all that is need so I won't have to do it again right away.
