No crank
Old Apr 11, 2008 | 12:04 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
No crank
Ok it's not truck related but Ford related, don't know were else to turn. My sister has the '01 taurus that I used to own. Could a bad alternator cause a no crank situation ? Replaced starter with no effect, checked all fuses and relays under the hood, all ok. Anyone have an idea? Thanks.
Moderators please don't boot me off for a non-PSD subject.
Old Apr 11, 2008 | 12:30 PM
powerstroke02's Avatar
powerstroke02
check connectoins on battery and charge of battery. if that checks out try a new ignition switch? Thats what i would do. maybe someone else can help better! good luck
Old Apr 11, 2008 | 12:47 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Not cranking (turning over ) or not starting?
Old Apr 11, 2008 | 12:59 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
No turning over, makes me think of a interlock switch somewhere. Or I'm barking up the wrong tree.
Old Apr 11, 2008 | 01:13 PM
joegebff's Avatar
joegebff
Probably on the right track. Not familiar with that vehicle, but there usually is an adjustable switch somewhere on the shift linkage. You said that you checked the relays. Were they getting activated? Will it crank if you jump across the relay?
Old Apr 11, 2008 | 01:39 PM
PaysonPSD's Avatar
PaysonPSD
Problem may be in the shifter not making a contact to tell ECM that vehicle is in Park or Neutral. I am assuming it is an automatic.
Old Apr 11, 2008 | 01:41 PM
fbilly420's Avatar
fbilly420
If it is an auto move the shifter up and down through the gears with your foot on the brake. It may make contact and start.
Old Apr 11, 2008 | 01:47 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Is there not a starter relay mounted on one of the fender wells? Probably the one closest to the battery. If the battery is charged try jumping the 2 large posts on the relay and see if it turns over. If you want it to start and you are lucky, have the key on when you try this but make sure it is in park first.
Old Apr 11, 2008 | 03:06 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Yes I 'll try try those things next, if it's like my truck, if you lock it with the remote you have to unlock with it or it won't start.
