Sponsored by: Real Truck
Emergency Brake
Old Apr 11, 2008 | 11:18 AM
Townman01's Avatar
Townman01
Emergency Brake
I have a 1999 Ford F550 7.3 Powerstroke Diesel. I have a problem with the truck dying whenever I release my emergency brake. It is a manual. Do you know what this could be caused by?
Old Apr 11, 2008 | 12:06 PM
03_PSD's Avatar
03_PSD
no its not normal, maybe some wires are grounding out causing the truck to die. try diging around under there and see if anything looks out of the ordinary.
Old Apr 11, 2008 | 12:09 PM
Townman01's Avatar
Townman01
Looked @ Ground Wires
Thank you for responding, I already checked the ground wires, someone else also suggested this might be the problem. Problem still not solved.
Old Apr 11, 2008 | 12:12 PM
03_PSD's Avatar
03_PSD
does it kill the truck if you release it slowly?
Old Apr 11, 2008 | 12:15 PM
Townman01's Avatar
Townman01
Respond
No, if I release it slowly by holding my foot on the e brake & letting it raise slowly it will not kill. It only does it if I just pull the release.
Old Apr 11, 2008 | 12:18 PM
03_PSD's Avatar
03_PSD
almost seems like there is something loose. maybe a ground or a fuse even. hopefully someone else will chim in for ya with better help.
Old Apr 12, 2008 | 03:56 AM
aldridgec's Avatar
aldridgec
Isn't the computer down there next to the parking brake? Sounds like the shock is messing up the computer or the connection. My guess would be the ECM.
