hose to carb
Old Apr 11, 2008 | 07:50 AM
reifwj's Avatar
reifwj
hose to carb
When I removed the factory carb there was a hose running from just behind the thermostat to the spacer under the carb. What is that for and is it required? The carter i just picked up has the spacer already and that conection is there but not sure what it is for. Is this required on the newer aftermarket stuff?
Old Apr 11, 2008 | 10:28 AM
wizzard351's Avatar
wizzard351
some FE engines use a water hose to the spacer to warm it up faster.
Old Apr 11, 2008 | 11:19 AM
reifwj's Avatar
reifwj
are there any other added benifits to it?
Old Apr 11, 2008 | 02:29 PM
montana_highboy's Avatar
montana_highboy
Those water spacers are there to cool the carb as well, 195 degree coolant is much cooler then the 350 degree intake manifold temps, though if keeping the carb cool is your primary concern a phelonic spacer would be a better option.
Old Apr 11, 2008 | 03:19 PM
reifwj's Avatar
reifwj
So it sounds required. I will be pulling the plug out of the space tonight when i get home and hooking up the hose.
Old Apr 11, 2008 | 06:41 PM
blue68f100's Avatar
blue68f100
If it's a single hose connection, it may be part of the PVC system, which should be connected. Normally it's in back of the carb. The Cooler/heating block (2 connections) connects to the heater hose port ( behind thermostat) to carb then to heater.
Old Apr 11, 2008 | 06:51 PM
reifwj's Avatar
reifwj
that's how it goes. I looked at my new spacer and it doesn't have the hose conections. I'm going to go with out it and see how it works. worst case i have to get a new spacer.
Old Apr 11, 2008 | 10:59 PM
wizzard351's Avatar
wizzard351
just plug the holes for the old hoses on the intake
Old Apr 11, 2008 | 11:02 PM
orich's Avatar
orich
Not sure of the date but when ford stopped using the exh manifold heat riser with countweight & spring is when ford started using the carb base heater. A few time on friend trucks had to bypass the carb beae heater inthe summer time due to carb boiling gas and flooding. ...my 2cents
orich
