Lower Ball Joint Question.
Old Apr 11, 2008 | 04:22 AM
Autoglass's Avatar
Autoglass
I just had the tires rotated and the tire guy says that I need the left lower ball joint replaced, Now granted the tire does wobble, but only after 15,000 miles????
The shop gave me an estimate for @ $250.00 total. Does that sound fair price or am I getting taken? Parts are $69.00 and labor is @ $144.00 + tax.
Old Apr 11, 2008 | 07:10 AM
bluesman2333's Avatar
bluesman2333
If you did it yourself, you could do it for about $30.00 plus a tool rental which is often free at the AP you buy the parts from. Since this is prolly your first time and it is a pain, it might be worth having it done rather than spending a day swearing at it.
Old Apr 11, 2008 | 04:17 PM
Autoglass's Avatar
Autoglass
Oh I swear at it more than I'll admit to. Took a trip last Friday to take care of personal business, filled both tanks to see what it would get fuel mileage wise,,,,SUCKS!!!!! It's a 300 I-6 w/ Auto. and it got a LOUSY,,, REPEAT,,, LOUSY MPG ! @ 6.5MPG! BUT!!!!! With it having 266,000 miles on it,,,It's wore out. It just a basic work truck.
Old Apr 11, 2008 | 04:39 PM
bluesman2333
Autozone.com has some basic instructions with pictures if you want to see what you would be getting yourself into.
Old Apr 12, 2008 | 07:20 AM
Autoglass's Avatar
Autoglass
"THEY GOT PICTURES??????? OH BOY!!!!!"
Old Apr 12, 2008 | 09:16 AM
bluesman2333
Why would you find that funny?
Old Apr 13, 2008 | 12:29 PM
Autoglass's Avatar
Autoglass
It's my sense of humor talking there.
Some of us guys figure a way to laugh at life and make it bearable.
As a friend of mine once said,
"If You Can't Laugh At Life, Resign!"
BTW, I'm almost 47(4-22-61), I need to have a little fun, Don't you think?
Old Apr 13, 2008 | 08:32 PM
mhg's Avatar
mhg
autoglass I got but of course I am over 50
by the way, go to the top of page, articles and specs.
look for ball joint replace on E150 van
same basic job on a truck
Old Apr 13, 2008 | 10:02 PM
bronco2454's Avatar
bronco2454
Off topic I think that 6.5 mpg sounds bad even for the mileage that is on the truck.
Old Apr 14, 2008 | 12:20 AM
Autoglass's Avatar
Autoglass
I'm planning on getting a Motorcycle,,, Get downsized again,,,, Went from 18 to 4 to 2!
But Unicycles are out of the question!
Around town it does ok, but out on the Interstate,,,,,,IT'S SUCKS!!!
Old Apr 14, 2008 | 05:08 AM
bronco2454's Avatar
bronco2454
is it a 3 speed auto or does it have od.
Old Apr 14, 2008 | 10:55 AM
doom899's Avatar
doom899
i just did ball joints
I just did my ball joints last weekend. I have a '90 f150 XLT Lariat - l6 - E4OD - 176,000 miles. I did all 4 of them myself. The total cost to me was about $50.00 (Considering I had my own jack and jackstands). However i will warn you because the ball joints are pressed in using a c-clamp like tool you should have a pipe to put on the end of your wrench and if you are doing it by just yourself (1 person), then you will need a solid vice that can take A LOT of tourque, because you will be cranking so hard. Also if there is a lot of rust on the underside of the front end you should probably be pretty strong to be able to break the rust on the bolts(WD40, etc). I am mainly talking about the bolt and nut that clamp down on the camber sleeve. Let's see you will need the balljoint set from advance auto and the fork tool set. This cost me a deposit of $180 and when I returned them I got it all back. The shop wanted to charge me about $800 and that was with a price break(milwaukee, WI). So I am glad to be able to do it myself for $50.
I have found very very cheap namebrand parts on autopartsgiant.com if you spend over $50 the shipping is free! If the shipping is free, sometimes it is cheaper than ebay, and like i said they have name brand stuff.
Old Apr 15, 2008 | 02:48 AM
Autoglass's Avatar
Autoglass
4 speed auto. w/ O/D.
