Decode
Old Apr 10, 2008 | 09:09 PM
AlabamaTruck's Avatar
AlabamaTruck
Decode
Please decode for me:
F10AL852574
129 M F100 281 C 09
5000 129 4000 63
The plate in the glove box says the sames except for the cab. It says
F100 81
Old Apr 11, 2008 | 02:46 AM
camperspecial65's Avatar
camperspecial65
what year is your truck supposed to be...glove box tags were used until 63 as I recall...64 up the tags were on the LH door...for the true VIN, check the RH frame rail on the topside and about parallel with the front crossmember...the numbers are about 1/4" high...and easily seen unless frame is badly rusted.
- cs65
Old Apr 11, 2008 | 08:00 AM
AlabamaTruck
Sorry,
It's a '66 longbed standard cab. It was repainted in '85 in a creamy white and red two tone. White is the primary color, red is the tone.
The numbers I posted are from the door tag.
The glovebox tag has the same number F10AL852574 on it. The tag is not fixed to the glovebox, but is IN the box. I thought it fell off and was going to ask where to attach it. So, where was this tag (plate)?
Old Apr 11, 2008 | 02:18 PM
bertha66's Avatar
bertha66
F10 - F100 2wd std cab
A-240 I6
L-Michigan
852574 made in Apr 1966
129 WB
M Corinthian white
C- 3sp trans
09-3:70 gears
5000GVW
Old Apr 11, 2008 | 02:30 PM
camperspecial65
The tag is attached on the rear of the LH door below the latch. Its riveted to the door.
The rest of the code is: DSO-63= Memphis and 281 = 2= Medium blue crush vinyl & blue wicker pattern vinyl.
81 is a conventional cab truck
This is a base model truck...has a round speedo most likely and not a Custom Cab model as I recall it being said that if theres a letter/s in front of the 81 and followed by a B thats a Customcab truck(an A would be a std cab though it seems not all were stamped on the door tags)
- cs65
Old Apr 11, 2008 | 05:12 PM
AlabamaTruck
thank y'all
Old Apr 11, 2008 | 07:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bertha66
F10 - F100 2wd
A-240 I6
L-Michigan
129 WB
M Corinthian white WIMBLEDON White / No Corinthian White after 1963.
281: Body Code **
C- 3sp trans Ford 3 speed manual all syncromesh transmission
09-3:70 gears
5000GVW Rating
129 HP @ 4000 RPM
DSO: 63 = Memphis, TN Ford District Sales (Zone) Office. Where the original selling dealer ordered the truck from.
**When a number is the first digit of the body code, the truck is a Standard Cab = 81A.
When a letter is the first digit of the body code, the truck is a Custom Cab = 81B.
Old Apr 12, 2008 | 03:52 PM
camperspecial65
aaack...my memory fails again...oh well...I knew I had a 50/50 shot :-)
- cs65
