off idle power drop
Old Apr 10, 2008 | 07:44 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
off idle power drop
long post here...my 83 f100 302 2v has a power drop off right off idle when accelerating. it acts like its leaning out, if u accelerate mildly off a stop, it will take off ok, but then the revs will drop , but u give it gas and it revs right up. i like 2 accelerate slowly, for fuel ecomony, but i kant anymore with this problem. i have a 3.16 gear, 31 inch tires, aod. my original gear was 3.55. my stock timing was 6 or 8 degrees , but i have it set at 10. i rebuilt the engine a few years ago and installed a tow/rv cam. i rebuilt the carb a couple months ago. secondary ignition is in good shape(spark plug gap, wires,rotor, cap). if i drive the truck more agressive, it drives just fine, but i can almost make the engine die acclerating off a stop if i get in the gas slowly. one thing i havent checked is the vacuum advance. engine runs good at highway speeds, and idles great. any ideas?
Old Apr 11, 2008 | 02:01 AM
HemiEater's Avatar
HemiEater
sound like the power valve...what kind of carb is it?
Old Apr 13, 2008 | 06:48 PM
oldfordtrucksrule
stock autolite 2 brl. the 2150 i think. i just replaced it when i rebuilt the carb a couple months ago(power valve i mean).i no alot of the problem is my rear tire diameter and lower than stock gear ratio, makin the truck acceletate like a dog,lol. ive got a set of 3.50 gears on the way though, thatll help some.
Old Apr 13, 2008 | 06:55 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
You might try advancing the timing a bit more. Keep going a couple of degrees at a time until you start to get a knock with a load at part throttle then back it down two - four degrees from there.
