Band adjustment
Old Apr 10, 2008 | 07:42 PM
going to the dogs's Avatar
going to the dogs
Band adjustment
I have a 95 4.0 auto 4x4 ranger and would like to adjust the bands to see if it would help the 2-3 flare that the truck has.A filter and flush will folow. I know the specs, 10 lbs and back off 2 turns on the od band. And 2.5 turns on the intermediate band. The problem is which band is which. Thanks for your help, Bill
Old Apr 11, 2008 | 07:59 AM
going to the dogs
Hello anybody there ?
Old Apr 11, 2008 | 08:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The overdrive band is the one towards the front of the trans.
Old Apr 11, 2008 | 09:56 AM
going to the dogs
Thank you.
Old Apr 11, 2008 | 10:10 AM
kermmydog's Avatar
kermmydog
DON"T FLUSH. JUST DRAIN THE PAN CHANGE FILTER. ADD LUBEGARD. I have seen nothing but grief with flushing. Had it done once on my C-6 & never again.
Old Apr 12, 2008 | 01:18 AM
Ken Blythen's Avatar
Ken Blythen
What happened?
Old Apr 12, 2008 | 11:35 PM
going to the dogs
As said above i have a 2-3 flare or slight increase in rpm on the 2-3 shift. I have gotten good at timing it and let off the gas as it shifts, and you dont even notice it. Some one in the ranger forum said that it can sometimes be cured by adjusting the bands, so we will give it a try. As for the flush i was just going to drain, change the filter refill and pump out through the return line fron the cooler.
Old Apr 13, 2008 | 06:26 AM
Mark Kovalsky
Are you going to drain the torque converter, too? If not, I wouldn't bother dropping the pan. Changing the oil in the pan without draining the converter changes less than half of the fluid. It's just a waste of time and money to put five quarts of new fluid in with about seven quarts of old fluid.
Old Apr 14, 2008 | 02:23 AM
Ken Blythen
Originally Posted by Ken Blythen
What happened?
I meant - What happened to Kermmydog's trans when flushed?
