Sponsored by: Auxito
Power for topper cargo light
Old Apr 10, 2008 | 07:20 PM
yotesniper66's Avatar
yotesniper66
I'm a new user and posted this on the announcements site, but not sure what kind of response I'd get, so I reposting here.
I just installed a jason topper on my 2003 F150 Supercrew 4x4. I've seen several posts on the 3rd brake light feed (green wire off harness), so that problem is solved. Now I'm looking for a power lead in the back for the cargo light. I have a factory tow package and was wondering if I can tap into the 7 pin harness. If so, which wire?
Old Apr 12, 2008 | 10:45 AM
coatit's Avatar
coatit
Smile
I'm suprised you don't have a bunch of help by now. I would tap into the power to the seven pin. I don't know which wire it is but it would be the hot one. You are also going to need a ground also. If anyone has a better idea I'm sure they will wade in.
Old Apr 12, 2008 | 10:58 AM
Ford Fx4's Avatar
Ford Fx4
You would what the black wire, This wire is only hot when the key is ON though. I have also seen people run a wire right from the battery down the frame to the back of the truck, this way you can turn the light inside the topper on regardless of key position.
Old Apr 13, 2008 | 10:41 PM
yotesniper66
Thanks for the replies. I'm also suprised that I didn't get more of a response, but yours is enough to help. I think I'll just run a feed from the battery and be done with it.
Old Apr 13, 2008 | 11:01 PM
coatit's Avatar
coatit
Lightbulb
that's what I would do, don't forget to put a fuse in line.
Old Apr 13, 2008 | 11:27 PM
khadma's Avatar
khadma
Carpenter Local 745
How do you want to activate the light?
Stand alone switch.
On when cabin light goes on.
On when you open door.
I say use a cabin mounted switch and activate the light only when needed.
How do you plan to use the light inside the topper.
hunter101
May 13, 2022 12:55 AM
shipfitter1966
Feb 17, 2008 07:19 AM
mjorda2
Electrical Systems/Wiring
Dec 13, 2007 12:00 AM
F250XL
Jun 24, 2007 03:00 AM
Hometown Pride
Apr 15, 2007 08:00 AM
